Upgraded Front Arb - Increased Rear Grip?
Posted 20 October 2018 - 07:45 PM
Have you found that adding a stiff antiroll bar has increased your corner exit rear grip?
I am considering fitting one to my car (Elise 111r) as at certain circuits I struggle with traction out of tight bends. I have Hoffman nitrons 1 ways fitted and have found that adding more damping to the front does help but want to keep it sensible so braking isn’t affected.
My handling set up is: r88r 225 fronts, 245 rears. Ride heights 120 mm fr125mm r, camber 1.2 degrees front, 2.2 rear, open diff.
Any help greatfully received!
Posted 20 October 2018 - 08:07 PM
Stiff front ARB = understeer (if you don't change other stuff to accommodate). I don't think you'll get any extra noticeable rear end grip myself.
Posted 20 October 2018 - 08:22 PM
Do you get even wear on on your rears BTW?
Posted 21 October 2018 - 03:17 AM
fitting 1" arb to mine transformed the car on track however i do have to disconnect it when its pissing it down
Posted 21 October 2018 - 06:30 AM
Did it help with (not) spinning the rear tyres up out of tight bends Joe? I struggle with one tyre fire and just thinking the car would 'hook up' better if it was flatter
Posted 21 October 2018 - 06:37 AM
Posted 21 October 2018 - 07:28 AM
Lsd...
considering it!
Posted 21 October 2018 - 08:28 AM
Posted 21 October 2018 - 09:31 AM
Joe has less torque than you Hugh
Posted 21 October 2018 - 09:33 AM
I have the 1" ARB front, and what everyone is saying it is making more understeer.
But my car seems to have a lots of grip out of corner. I don´t Think I have a LSD.
But it can be that the stronger ARB is preventing the inner rear wheel to lift.
Br, Per
Posted 21 October 2018 - 09:34 AM
Lsd...
I think this is the main answer I also struggle when sprinting hugh with corner exits
And on track days
I've changed various cambers and toe to try and conquer this but you end up moving the issue rather than solving it
Lsd has to be the answer
Posted 21 October 2018 - 09:36 AM
ARB geo and shocks and springs
To really pin point what caused it
But saying that I still had the issue before allof the above
The truth is the more aggressive you are ( when competing ) you are always going to overdrive the car
To try a steal a advantage
Edited by CHILL Gone DUTCH, 21 October 2018 - 09:37 AM.
Posted 21 October 2018 - 09:43 AM
Posted 21 October 2018 - 09:45 AM
a larger front arb will deffo give you more understeer if you just plonked it on, i had a day tweaking my shocks until i found something which made the car turn in again. i think now i have managed to find something good i would rather have it than not have it.. and i don't get many / if any problems with rear wheel spin, but the tyres were always up to temp.
do you have any pics of the car where you are experiencing the wheel spin from a track photographer or anything so we can see how the car is sitting?
what kind of speeds are you experiencing the wheel spin?
how tight are the corners?
what gear are the corners being taken in?
which track and corners specifically are you experiencing it?
Posted 21 October 2018 - 09:46 AM
What Nitrons do you have 40 or 46's
Posted 21 October 2018 - 12:07 PM
Removing the arb helped loads in the wet and reduced spinning if that helps
Posted 21 October 2018 - 01:36 PM
Posted 21 October 2018 - 02:09 PM
Posted 21 October 2018 - 04:46 PM
I Changed far to much on the setup of the car
I put a couple of clicks extra front damping in at Curborough and it instantly felt less snappy and I got an improvement in grip. Lap time dropped half a second too so I know it’s a front roll rate problem.
I think I will give the 1inch ARB a go,
Posted 21 October 2018 - 04:53 PM
A little bit of understeer isn’t necessarily a bad thing especially if it’s on corner exit. My car rotates like a beast which is fun but not necessarily the quickest way around a circuit.
Looking at photos of my car on sprints I do get quite a bit of roll pitch on certain corners (Anglesey Rocket entry and the bus stop).
I am pretty sure a roll bar might make me a bit quicker on certain circuits.
Any one got one for sale before I raid eliseparts?!
