The movement and positioning of the electronic throttle pedal sensor/potentiometers are fixed as they are based on dual opposing potentiometers inside. One will go from 0 ohm to max while the second goes from max to 0 ohm in the full stroke of the pedal.
This is the basis of the whole electronic pedal setup with it's fail-safes/checks built-in and the standard ECU (even when modified) can't really change much in that area.
On an aftermarket mappable ECU with ETB support (Eg. MOTEC, Syvecs, etc.) you might be able to let it re-calibrate the '0' position and/or also change the travel to go from 0% to 100% throttle.
With the normal ECU you can usually only adjust things by rotating the acutal pedal on the shaft (or bending the original pedal shaft..), but the angle of rotation / travel the shaft makes will have to remain the same.
Also you must make sure that the throttle potentiometers are fully returned to their base/'0' location as the ECU does not like it if the pedal is partly actuated/pressed when turning on the ignition as it gets into a strange offset and it often causes diling issues and strange throttle response.
