Windscreen Smearing On Wiper Use
12 replies to this topic
#1 kmidderigh
kmidderigh
  • 349 posts
Posted 18 November 2018 - 04:46 PM
So i thought it would be a good idea to use RainX on my windscreen a while ago - seemed fine at first when it was actually raining. Wipers cleared the screen ok.
However in the dry when you have just got some dirt on the screen and you want to wiper it off the results were awful - such bad smearing that I had to pull over and clean it off by hand :-(
So I cleaned the windscreen with 50/50 mix of white vinegar and water to remove the RainX coating - however I'm still getting bad smearing.
Had a go at cleaning the wiper blade itself today in case this helps - seemed ok after when using the wipers stationary and pouring water on the windscreen to simulate rain - but until I try again when dry and driving its hard to tell if ive fixed it....
Is RainX hard to remove ?
might I have contaminated the wipers blades ?
Unless wipers blades start to smear when they get old (although not seen this before)
Thoughts, advice ?
Ta.
#2 ayresyy
ayresyy
  • 488 posts
Posted 19 November 2018 - 07:45 AM
  Could just be the blade if its old, or the spring not strong enough it misses/smears in the middle of the screen. I have used Rainx several times on many different cars and not had any issues. It normally only lasts a few weeks before the effects ware off.
#3 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 19 November 2018 - 08:36 AM
You’ll need to re-apply it, every few weeks. Try to avoid using wipers to make it last longer. If you don’t re-apply you’ll eventually start getting black residue from the wiper blade on your windscreen.
#4 oakmere
oakmere
  • 2,143 posts
Posted 20 November 2018 - 02:26 PM
Rain x took an age to remove from my screen despite using solvents etc to get it off. It works great if you top it up all the time but is a pain in the ass when it starts to wear off.
Clean the screen a few more times and give it a few weeks and you should be ok.
#5 siztenboots
  • 26,610 posts
Posted 20 November 2018 - 02:42 PM
brake cleaner
#6 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 20 November 2018 - 03:21 PM
brake cleaner
WD40
#7 Talk-torque
Talk-torque
  • 150 posts
Posted 21 November 2018 - 07:51 AM
I never could get Rain-X to work properly. Great idea, though, especially for cars like ours. Anyone tried the new nano technology products?
#8 C8RKH
C8RKH
  • 777 posts
Posted 21 November 2018 - 08:03 PM
I use Rain x and have no issues. Don't follow the instructions though as I just squirt it on the screen and spread it with a cloth, leave it 2 minutes max, then polish with a clean cloth and it works superb, the rain just beads off.
#9 Ali87
Ali87
  • 1,287 posts
Posted 21 November 2018 - 11:53 PM
Sounds like you need a new wiper blade. I use rainx with no issues
Edited by Ali87, 21 November 2018 - 11:54 PM.
#10 Bakazan
Bakazan
  • 227 posts
Posted 22 November 2018 - 07:26 AM
Try a 22" PIAA wiper.
#11 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 22 November 2018 - 04:10 PM
It’s a well known issue on the standard set up of the VX.
Simple cure it to retrofit a Master Van (or similar) blade with a spray bar which is then vacuumed to your screen washer pump. Lots of info on here on how to do it.
Jon
#12 turbo boy
turbo boy
  • 1,161 posts
Posted 22 November 2018 - 04:11 PM
Jon
#13 kmidderigh
kmidderigh
  • 349 posts
Posted 24 November 2018 - 11:04 AM
Thanks for the advice - will change the blade, must be a few years old now anyway (i have the wiper bar spray mod already )
