Roll Hoop Removal
Posted 25 November 2018 - 09:49 AM
Thanks in advance
Sent from my SM-G935F using Tapatalk
Posted 25 November 2018 - 11:30 AM
It is not an easy job and you will need to cut some fibreglass to replace the metal roll bar
Posted 25 November 2018 - 02:52 PM
What are you fitting in its place? A cage? When I fitted my cage I just cut the roll bar in half and took it out. Have you cut the rear window frame off it yet?
Edited by fiveoclock, 25 November 2018 - 02:52 PM.
Posted 27 November 2018 - 03:55 PM
Posted 27 November 2018 - 07:09 PM
If you're not going to use it again just chop it in half, no body damage then, you can use a wire to cut the window frame/firewall off
