Why doesn't it fcuking fit seeing as every thread on here says it does?
C20Let Clutch Issues.
Posted 03 December 2018 - 07:21 PM
Posted 04 December 2018 - 07:49 AM
What part isn't fitting Mark?
Posted 04 December 2018 - 12:44 PM
It does fit (my sc has one) , whats the issue ?
Posted 04 December 2018 - 12:51 PM
The only thing you may have to slightly mod in the clutch cover mounting holes - an OEM flywheel was fine, but the billet flywheel used slightly large bolts, so just opened up the holes with a drill slightly. Fitted fine after that.
Posted 04 December 2018 - 05:24 PM
Turns out it is a C20XE pressure plate in a C20LET box.
Posted 05 December 2018 - 07:50 PM
Ah!
Posted 05 December 2018 - 08:14 PM
why did you order a c20xe clutch
Posted 05 December 2018 - 09:40 PM
c20xe uses the F20 gearbox, which is why it will not fit
