2Forge Zf1 Wheels
14 replies to this topic
#1 piwo
piwo
  • 178 posts
Posted 29 December 2018 - 04:59 PM
https://2forgewheels.com/2forge-zf1/
Is it worth something?
#2 pete-r
pete-r
  • 2,771 posts
Posted 30 December 2018 - 12:59 AM
Not sure of the cost for them, but I would swap the wheel hubs for lotus 4x100 and fit the forged lotus rims.
Best wait until you need new discs cos you'll have to swap them at the same time.
Best chassis mod I've done to my car by miles.
#3 piwo
piwo
  • 178 posts
Posted 30 December 2018 - 01:24 PM
I Ask something more.
With 17x 9'(245mm tires) what's should be a et? 15 ?
And on front with 17x8 (215 mm tires) also 15 et?
#4 piwo
piwo
  • 178 posts
Posted 30 December 2018 - 01:45 PM
Camber -3° toe +30' rear And -2° And -30' front
Edited by piwo, 30 December 2018 - 01:47 PM.
#5 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 December 2018 - 07:47 AM
I think ET rear xhould be 30
And fron ET20. If you havent modded
Your fenders?!
Br, Per
#6 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 December 2018 - 07:49 AM
Are thoae toe figures total or by side?
Br, Per
#7 piwo
piwo
  • 178 posts
Posted 31 December 2018 - 04:27 PM
Total.
I see ats dtc has et30 with 9' on rear And et20 with 7,5 on front. But front don't look good And i think et15 will look much better.
I have now 8' And et 35 And 225 tires And tires rub on an inter wheels
Arches And with 20mm spacers ( et 15) tires rub on an outer wheels arches. And now i Want to go to 245/40r17 tires.
Edited by piwo, 31 December 2018 - 04:37 PM.
#8 2-20
2-20
  • 1,317 posts
Posted 01 January 2019 - 05:19 PM
I have front 8x17 ET 35 +15 mm shims (=et20)
And the same wheels without shim at the rear.
I have 215/ 45 front and 245/40 rear.
#9 2-20
2-20
  • 1,317 posts
Posted 01 January 2019 - 05:22 PM
Nothing rub for me....
But I modified the rear of the front wheel well
#10 piwo
piwo
  • 178 posts
Posted 01 January 2019 - 05:30 PM
Maybe You have different camber And toe then i.
#11 2-20
2-20
  • 1,317 posts
Posted 01 January 2019 - 09:15 PM
Yes, that and the tyres ( profile can be more rounded on some) play a big role as well
#12 2-20
2-20
  • 1,317 posts
Posted 01 January 2019 - 09:29 PM
225 front tyres on Et15 wheels will obviously lead to tyres rubing the arches...
Why do you want to go even bigger ??
#13 piwo
piwo
  • 178 posts
Posted 02 January 2019 - 04:54 AM
for trackdays. need more speed in corner.i have team dynamics 16x7et20 (20mm shims) 195/50r16  avon zzr a24 and 17x8et35 (20mm shims) 225/45r17 avon a64 on rear. i want 17x9 (et~25-30) 245/40r17 extreme vr2 r7 on rear and 17x8 (et ~15-20) 205/45r17 pirelli trofeo r on front. that's how I see it.
Edited by piwo, 02 January 2019 - 04:55 AM.
#14 2-20
2-20
  • 1,317 posts
Posted 02 January 2019 - 03:04 PM
The ATS DTC would be a good candidate for your needs.
But you don't need 9 inches wide wheels for 245/40/17 tyres. 8 is sufficient and lighter.
#15 piwo
piwo
  • 178 posts
Posted 02 January 2019 - 03:56 PM
On a narrow rim tire badly laid and the edge of the tire rubs strongly.
My front 195mm tires on 7' rim
http://forum.rxklub....-1493532994.jpg
colleagues from the track recommend for 245mm 9'
