Turbo Not Starting When Hot
4 replies to this topic
#1 Paul~vxT
Paul~vxT
  • 238 posts
  • Interests:Engineering
    Restoration
    Fabrication
Posted 02 January 2019 - 10:14 AM
Basically it starts from cold and runs absolutely fine, but it won't restart when the engine is already hot. The car has been sat on the drive under a cover but I'm thinking maybe some engine sensors have gotten damp? Any idea where to start? Also, when it won't start I can't hear the fuel pump prime. As soon as it's cooled down it'll start again and run up to temperature. It does not cut out, but once I've switch it off that's when it won't start again.
Thanks.
Sent from my SM-G965F using Tapatalk
#2 siztenboots
  • 26,430 posts
Posted 02 January 2019 - 12:46 PM
cheap things to try , check the relays in the boot
#3 Duncan VXR
Duncan VXR
  • 5,246 posts
Posted 02 January 2019 - 01:00 PM
Yep as Steve points out check relays ;) also check earths & connector of doom :)
DG
#4 slindborg
  • 22,528 posts
Posted 02 January 2019 - 01:05 PM
if its only while hot, that sort of points to a sensor
#5 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,358 posts
Posted 04 January 2019 - 12:43 AM
My old tubby used to do this, fuel pump relay was faulty.
