Cleaning Inside Of Rear Window?
9 replies to this topic
#1 Eddles
Eddles
  • 79 posts
Posted 13 January 2019 - 09:39 PM
So I finally got some time to clean the filthy windows of my new car, and discovered that there are 2 patches of inside window I can't clean due to a pair of black thingies that's attached to the roll bar - how do I get behind those two?  Cheers!
#2 aquilaproejct
aquilaproejct
  • 150 posts
Posted 14 January 2019 - 01:35 AM
A large cloth and stuff it in behind.
Lots of scrapes to fingers
#3 ICD
ICD
  • 10 posts
Posted 14 January 2019 - 09:59 AM
Take them off. It also provides a couple of more inches of leg room at the same time.
#4 smiley
  • 9,883 posts
Posted 14 January 2019 - 10:01 AM
Rear thingies are velcrod on.
#5 Eddles
Eddles
  • 79 posts
Posted 14 January 2019 - 10:59 AM
Oops.  What are they for, anyway?  Cheers!
#6 fiveoclock
fiveoclock
  • 9,305 posts
Posted 14 January 2019 - 11:17 AM
Some say that in an accident you will die horribly without them.
#7 siztenboots
  • 26,372 posts
Posted 14 January 2019 - 11:21 AM
cleaning windscreen also a bit of a pain too , just wait until you try to open the front bonnet
#8 Eddles
Eddles
  • 79 posts
Posted 14 January 2019 - 11:37 AM
If they're velcro'd on, they won't be much use in an accident!  Have opened the bonnet a number of times, no issues (yet...).  While we're on this subject, what exactly is the issue that a number of people have and how do I fix this?  Cheers!
#9 smiley
  • 9,883 posts
Posted 14 January 2019 - 12:05 PM
Underneath the padding are some steel spoons welded on your rollbar.
The rear padding is velcro'd on. When you remove that you see 3 bolts that can remove the front side padding.
With both gone, you only see the metal spoons.
Some remove it to give aftermarket seats a bit more space to go backwards.
#10 Eddles
Eddles
  • 79 posts
Posted 14 January 2019 - 12:08 PM
Ooh that makes sense now.  Thanks.  Do they just come off, or do I have to pull downwards, or there's a special way to do it hopefully not involving sacrifice of my firstborn?
If I bothered to read your message properly, I'd have seen you've already told me how to do it.
Edited by Eddles, 14 January 2019 - 12:10 PM.
