Tire Size Advice
Posted 18 January 2019 - 10:38 PM
Posted 19 January 2019 - 12:35 AM
195 50 16 & 225 45 17
Posted 19 January 2019 - 09:08 AM
Posted 19 January 2019 - 11:30 AM
Posted 19 January 2019 - 11:31 AM
Edited by fiveoclock, 19 January 2019 - 11:31 AM.
Posted 19 January 2019 - 11:48 AM
And that size will be ok going from a 175/55/17 as is much smaller
Depends what you mean by ok ?
It will turn in sharper.
There will be more grip because its a bigger contact patch.
It will look a bit crap on a car on standard suspension because its a smaller diameter wheel/tyre in a wheelarch designed for a 17" wheel. There will be a big gap.
Posted 20 January 2019 - 12:35 AM
Many others use 205 45 on the front.
Posted 20 January 2019 - 08:54 AM
I've tried a variety of tyre profiles on the front and my advice would be to use a tyre with as much profile as possible (for the road anyway), as it lends itself to absorbing the ripples and undulations in the tarmac.
Posted 20 January 2019 - 09:29 AM
BTW, I meant that for the fronts, the rear profile isn't as important, probably due to the weight over the axel.
Posted 20 January 2019 - 12:39 PM
Posted 20 January 2019 - 07:29 PM
Take into account that your front/rear wheel rotation ratio will change and this could have an effect on your ABS.
When i went to 16 fronts the abs didnt like it at all. Easily solvec with a delete switch though.
