Drifting A Vx220
24 replies to this topic
#1 alanwetherall
alanwetherall
  • 110 posts
  • Interests:Playing Tennis, watching TV car programes, enjoying my retiremnet
Posted 04 February 2019 - 02:34 PM
I have just watched an old Top Gear episode with three Japanese car drifters trying to show the Hamster how to drift a Vauxhall VXR (400 bhp) around a track.  They made it look so easy but he was quite simply rubbish. Then I had an out of body experience and thought has anybody ever tried to drift a VX220.
The tell me its dead easy on a wet winter road corner but you usually end up in a ditch. There has  got to be a You Tube video of some nutter trying it.
#2 slindborg
  • 22,534 posts
Posted 04 February 2019 - 02:41 PM
"drifting" as in the shitty NOT motorsport, or do you mean just hooning about sideways lots and being super cool?
if its the latter, I found that the Lotus 340R road geo settings and reasonable tyres meant for a very controllably slidey car which was a giggle
For camp drifting, then you may aswell weld the diff up and go
#3 siztenboots
  • 26,464 posts
Posted 04 February 2019 - 02:52 PM
swap front and rear wheels round
#4 navx
navx
  • 365 posts
Posted 04 February 2019 - 03:40 PM
LSD is your friend. Without it, good chance you will end in a hedge. There us a video of someone doing doughnuts in the snow. They had a LSD fitted.
#5 Rosssco
Rosssco
  • 3,968 posts
Posted 04 February 2019 - 03:55 PM
With enough LSD you don't even need a car  thumbsup
#6 hairy
hairy
    Moonlander
  • 5,355 posts
Posted 04 February 2019 - 05:23 PM
#7 oblomov
oblomov
  • 3,645 posts
  • Interests:None
Posted 04 February 2019 - 06:58 PM
Should I admit I can vouch for that?
#8 SteveA
SteveA
  • 9,084 posts
Posted 05 February 2019 - 04:28 PM
I did a Caterham drifting thing with Bookatrack in December. Even in a car like a Caterham which is very evenly balanced between front and rear axles it requires incredibly delicate throttle control to maintain a drift without spinning (it was a very wet day). I imagine this is even more true with a VX. It took me a good hour in the seat to be able to control and start linking drifts together in a massive car park with plenty of run off and nothing to hit but cones. I wouldn't try drifting a VX without a good bit of practice in a very safe environment.
#9 james.a
james.a
    Proud member of the Northants Pedantic Crew
  • 2,021 posts
  • Interests:Driving Trigger's broom since March 2010
Posted 05 February 2019 - 05:00 PM
I can wiggle the back end on a roundabout but rapidly suffer from Bravery Deficit Disorder compounded by its co-morbid condition Lack of Talent Spectrum Disorder. Still in the dry you can give an NA a boot load out of a junction and it's generally very forgiving and predictable. Not sure I'd be so confident with a tubby or highly tuned version.
#10 Aerodynamic
Aerodynamic
  • 1,269 posts
Posted 05 February 2019 - 05:31 PM
I´m trying to reduce the rear end weight because I want to be less suprised by the rear end.
Also if you have the right tire and a not so wide rear tire it will also be simpler.
Anyway I was at a cone track day last year when it was a little dump condition
and then I could get a controlled rear end slip, but this was also due to the lower speed.
Much harder to do in a fast conerering.
#11 Bargi
Bargi
  • 4,476 posts
Posted 05 February 2019 - 05:46 PM
VX and associated Loti are shite for showboat drifting. Don't have enough steering lock.
Sent from my SM-G950F using Tapatalk
#12 chris_uk
    I fancy chill
  • 9,798 posts
Posted 05 February 2019 - 07:14 PM
power sliding lol
Edited by chris_uk, 05 February 2019 - 07:15 PM.
#13 SteveA
SteveA
  • 9,084 posts
Posted 05 February 2019 - 07:27 PM
That’s just catching a slide in my eyes. I think a true drift is where you provoke a slide, countersteer then use the throttle to maintain the slide and adjust the yaw angle (like you see Firthy do in his wet vids) I could always catch a slide but was useless at drifting until I did that course. I’m still not great at it 😄
#14 turbo boy
turbo boy
  • 1,108 posts
  • Interests:Cars, fitness, fishing, sports
Posted 05 February 2019 - 08:59 PM
Hi Alan,
As suggested here by others, the VX is not a car suited to drifting. The NA is easier to control, the turbo is too rear heavy and difficult to control when the pendulum effect begins...
A LSD would help as would skinnier tyres. It’s a terrific track car to hustle but not a drifter 👍
#15 Exmantaa
  • 3,872 posts
Posted 05 February 2019 - 11:47 PM
Read somewhere that Lotus increased the max steering angle on the V6, as the "natural drift angle" was more than the standard rack could reach. Think they only used shorter steering arms for that (gives more angle and a quicker rack), so a pair of those new adjustable Spitfire steering arms should do the trick. :happy:
#16 Exmantaa
  • 3,872 posts
Posted 06 February 2019 - 12:05 AM
Found the article:
http://www.carmagazi...-s-2012-review/
The interesting parts:
What are the key changes under the skin of the 2012 Exige S?
There’s a faster steering rack, dropping the ratio from 18.5:1 to 17.25:1. The rack isn’t new, the ratio change instead coming from a shorter effective lever ratio. Combined with a wider front track, this has also created more steering lock, making it easier to hold powerslides. Now, this sounds childish, but it’s actually very important, because the old car ran out of steering angle perilously close to the point at which you naturally balanced the car during a slide, namely 32 degrees. This now rises to 35 degrees, reducing the potential of hitting the lockstops and thereby reducing the risk of the car spinning. You can genuinely feel the flexibility this brings when you play around on a racetrack.
There’s also a wider rear track, an entirely new rear subframe, plus revised springs and dampers all round. Meanwhile, Lotus has built an anti-squat angle into the suspension wishbone, helping to prevent, yes, squat under acceleration, and the lateral stiffness of the rear of the Exige increases by 100%, ensuring the car rolls along its centre-line through corners, where the old Exige could roll diagonally as the structure flexed. All this creates a virtuous circle. ‘Previously all the roll control was done by the springs and dampers,’ says chassis guru Matt Becker, ‘so they were stiffer than we’d have liked. And the extra lateral stiffness has allowed us to introduce an anti-roll bar. The old car wouldn’t have coped with the faster steering and the anti-roll bar – the rear axle would have always given up first.’
#17 Spitfire Engineering
  • 713 posts
Posted 06 February 2019 - 12:29 PM
That they would!
And you could sort the bump steer out at the same time   :)
Edited by Spitfire Engineering, 06 February 2019 - 12:29 PM.
#18 SteveA
SteveA
  • 9,084 posts
Posted 06 February 2019 - 02:14 PM
#19 james4563
james4563
  • 267 posts
Posted 06 February 2019 - 08:11 PM
Is that in an NA?
My tubby gave me a brown pants moment just going onto a dual carridgeway the other morning. Pretty gentle accel in 3rd gear and just stuck the back to the side....  :huh:. Can't imagine actually trying to drive it fast intentionally in the wet haha.
#20 Firthy
Firthy
  • 536 posts
Posted 06 February 2019 - 09:42 PM
Is that in an NA?
Yes its a very old video of mine :) when it was n/a here are some newer vids with faster skids..... :)
My mate following me in his N/A exige short box + diff :)
