2.2 N/a Engine
Posted 18 February 2019 - 09:24 AM
Posted 18 February 2019 - 12:36 PM
Just check its not a 2.2 direct as these dont fit.
As far as the vx you will need to swap the oil cooler bypass and housing across otherwise a direct fit
Posted 18 February 2019 - 03:39 PM
has your engine died, or you just fancy swapping the lump as its lower milage? (not a gauge on being a better engine btw)
Posted 18 February 2019 - 06:54 PM
confirm its a z22se not a z22yh, easy way to do this is to compare the coilpacks.
Posted 18 February 2019 - 10:13 PM
Neither but ive had a few issues with Oil leaks on track days so was thinking about getting a spare and getting it in a decent state of service to use as a spare should the worse happen
Posted 18 February 2019 - 10:14 PM
not sure what a 2.2 direct is. How do I know the difference?Just check its not a 2.2 direct as these dont fit.
Posted 18 February 2019 - 10:32 PM
look at my post above
Posted 19 February 2019 - 06:02 AM
