Supercharger "rattle"
10 replies to this topic
#1 Foxy
Foxy
    I love Nev
  • 10,361 posts
Posted 26 February 2019 - 02:39 PM
I thought my chains were getting a little rattly so I popped by to see Gavin at Unit 4 to see what he thought.
He said that he thought the noise was coming from the SC not the chains.
I've not heard of anyone having this issue before - is it a known problem and what could the cause be?
#2 Haston
Haston
  • 196 posts
Posted 26 February 2019 - 03:01 PM
I had an R53 Mini that it sounded like the engine had a bag of marbles rattling around in it and it ended up being the SC had ran dry of oil (common problem on the M45)
I ended up listening to it through a screwdriver to work out what it was.
#3 FLD
    Batmans mum says 'I like things in my bum'
  • 13,218 posts
Posted 26 February 2019 - 03:30 PM
How about the damper spring in the coupler. These are a known failure on the M62.
#4 Exmantaa
  • 3,867 posts
Posted 26 February 2019 - 03:34 PM
It's more a coupler disc (from plastic) that gives a supercharger rattle when worn. A cheap piece, but first check without drive belt if your noise is gone. (could also be the alternator...)
#5 Foxy
Foxy
    I love Nev
  • 10,361 posts
Posted 26 February 2019 - 03:43 PM
Thanks all. Dot org to the rescue :D
Coupler definitely prime suspect. Symptoms and noise match the descriptions.
chinky chinky
#6 FLD
  • 13,218 posts
Posted 26 February 2019 - 04:47 PM
I thought the coupler had a spring onto the rotors and the upgrade was just a disc.  like this:
http://www.superchar...ge/couplers.jpg
#7 FLD
  • 13,218 posts
Posted 26 February 2019 - 04:49 PM
Linky for foxy
http://www.superchar...page=page&id=57
#8 Foxy
Foxy
    I love Nev
  • 10,361 posts
Posted 26 February 2019 - 05:51 PM
Thanks Matt - I'd fit an OEM if I could find one, but Joe reckons the pattern ones without the spring will be fine thumbsup   :blink:
#9 tommobot
tommobot
  • 910 posts
Posted 26 February 2019 - 06:33 PM
Is there a way to check / top up the oil in the SC?
I feel I should hand in my keys after asking that! :(
#10 Haston
Haston
  • 196 posts
Posted 26 February 2019 - 07:20 PM
I know you can buy a service kit with oil and syringe for the M45.
I think someone on the Z22SE forum serviced one if you check there
#11 Foxy
Foxy
    I love Nev
  • 10,361 posts
Posted 26 February 2019 - 07:33 PM
AIUI it doesn’t need changing in road cars, so not a stupid question. For track use you can change it by syringing it out. Described in FLDs link above.
