Clutch Release Bearing Height
4 replies to this topic
#1 italikko
italikko
  • 13 posts
Posted 06 March 2019 - 10:47 PM
My previous clutch system was a lightweight single mass flywheel with helix disc.
It was working fine and had no slack on the pedal.
The full length of the system when I measure from flywheel bottom flat surface to the edge of the pressure plate tooth is 59.09mm.
The new clutch system i have picked for my build has a length of 50.94mm.
So it is 8.15 mm shorter.
Should I use a spacer for the clutch release bearing?
Edited by italikko, 06 March 2019 - 10:50 PM.
#2 Johnboyhgt
Johnboyhgt
  • 1,041 posts
Posted 07 March 2019 - 10:56 AM
is that clamped in place on the flywheel or just on the desk etc ?
#3 italikko
italikko
  • 13 posts
Posted 07 March 2019 - 11:18 AM
I have bolted both systems to the same flat surface.
Both systems where torqued to spec.
Edited by italikko, 07 March 2019 - 11:18 AM.
#4 Johnboyhgt
Johnboyhgt
  • 1,041 posts
Posted 07 March 2019 - 01:01 PM
Something not quite right there !!
#5 italikko
italikko
  • 13 posts
Posted 07 March 2019 - 02:10 PM
How it should be done?
The all the reference points are the same except the pressure plate tooth.
