Hi does anyone have any experience with removing the exhaust manifold (Turbo) - There are 10 Nuts but the clearance between some of the lower ones and the manifold is very small - Do i need some sort of special thin walled sockets or something ?? - 1 of the nuts (as far as i can see) can only be removed by using a male torx key - This is fine as the studs are far enough back from the end of the nut but if i fitted new studs they appear to be longer with a torx head and im not sure i could re-fit the nut using a male torx key
Any suggestions as always are very much appreciated
Cheers
Tony
