Aluminium Bolts/zinc Coated Clips For Undertray/diffuser?
8 replies to this topic
#1 Eddles
Eddles
  • 79 posts
Posted 16 March 2019 - 10:20 PM
I'm sure this has been discussed to death, but I am wondering whether I could use aluminium bolts and zinc coated clips for the engine undertray and rear diffuser?
Cheers!
#2 Johnboyhgt
Johnboyhgt
  • 964 posts
Posted 16 March 2019 - 10:54 PM
I use nylon washers.
#3 Ormes
Ormes
  • 4,482 posts
Posted 18 March 2019 - 06:11 PM
Before understanding galvanic corrosion, I used S/S and managed to corrode the tray slightly.
I now use BZP washers, spire/c clips and button heads, all with a bit of copper slip.
I assume you are considering aluminimum due to corrosion resistance, but they could be a total and utter nightmare if you strip the threads, which is likely over time with alu.
I would do as I do but hey, what else am I going to say :)
#4 Eddles
Eddles
  • 79 posts
Posted 20 March 2019 - 07:39 PM
Ormes - sounds ideal to me!  What about the bolts themselves - mild steel, BZP, or stainless?
Cheers - Piers
#5 Ormes
Ormes
  • 4,482 posts
Posted 20 March 2019 - 09:19 PM
I just use BZP everything, including the bolts thumbsup
#6 FLD
    Batmans mum says 'I like things in my bum'
  • 13,140 posts
Posted 22 March 2019 - 12:00 PM
I use the quick release fasterners that A4 bolt man does. Can't remember his website to post a link but they are great IMO. I think these are a plated steel clip with a chrome plated steel pin which also has a nylon washer.
#7 hairy
hairy
    FLD’s fluffer
  • 5,251 posts
Posted 22 March 2019 - 02:51 PM
:yeahthat:
#8 chris_uk
    I fancy chill
  • 9,767 posts
Posted 23 March 2019 - 04:50 PM
i just used nylon washers with the standard bolts and washers.
#9 oakmere
oakmere
  • 2,085 posts
Posted 25 March 2019 - 12:26 PM
I use stainless bolts and washers with a nylon washer between.
This stopped the corrosion of the alloy. Painting the diffuser has also helped.
