Boot Lock Removal
3 replies to this topic
#1 Mat Jackson
Mat Jackson
  • 1,141 posts
Posted 24 March 2019 - 12:57 PM
Just taking the rear clam off and coming to the boot lock. I can see the two button heads to take out, but once removed how do I then take the lock out itself?
#2 vocky
    vx220 itb
  • 11,642 posts
Posted 24 March 2019 - 04:55 PM
once the two M8 hex bolts are removed the lock is loose, simply pull it out from behind the foam heat shield all the way to the wheelarch, otherwise the clam will not come off
#3 vocky
    vx220 itb
  • 11,642 posts
Posted 24 March 2019 - 04:56 PM
if you want to remove the lock, then undo the small bolt on the inner cable (think it's a 5.5mm head) and remove the complete cable.
#4 Mat Jackson
Mat Jackson
  • 1,141 posts
Posted 24 March 2019 - 07:29 PM
Thanks Vocky - I couldn’t see it as I’ve got an extra sheet of heat proofing for the 4-1 manifold...
