Hello
This topic is about Opel Speedster Turbo 2005.
I have removed the engine and restored/tuned it. Changed all bearings and conrods. Slightly higher turbo pressure, sharper cams, slightly bigger injectors, performance exhaust/inlet system, engine mounts, harder suspension, short shift etc.
Now I have mounted the engine again and connecting oil, water, electrics etc. But the vacuum box for the inlet system, I ca´t figure out where it should be mounted. The two thin hoses are to be connected on the left side of the inlet manifold/injection system, and I was thorough enough to mark the hoses and the connection to inlet, but still I can´t see the mounting points for the box. Suspect under the inlet manifold, close to the generator...
See also attached pic, where I hold the box in my hand.
Joakim
