Knocking Noise...
9 replies to this topic
#1 Rickybobby
Rickybobby
  • 27 posts
Posted 04 April 2019 - 07:00 PM
I have knocking noise when doing anything but braking; I tap the brakes and it goes away but quickly returnes.
It’s been there for the year I’ve owned it and it’s now on its 2nd set of pads and still there so my thinking it was the brakes is out.
Next port of call CV joints?
Are these common and what can I look for with the wheels up in the air?
Do they just need repacking or replacing, if so where to buy them from or will finding a good used complete set of driveshafts be a better option?
#2 Ormes
Ormes
  • 4,499 posts
Posted 04 April 2019 - 07:27 PM
Pads rattling in the calipers?
#3 smiley
  • 9,928 posts
Posted 04 April 2019 - 07:32 PM
Pads.
#4 Rickybobby
Rickybobby
  • 27 posts
Posted 04 April 2019 - 08:58 PM
That’s what I thought, any ideas on stopping it?
#5 smiley
  • 9,928 posts
Posted 04 April 2019 - 09:37 PM
The pads should be so close to the disk, that there is hardly room for a wobble/rattle.
So start with removing the pads, and inspect them. Are they worn even?
These are an option.
https://www.elisepar...e-brake-buffers
https://www.elisepar...al-silencer-kit
Edited by smiley, 04 April 2019 - 09:39 PM.
#6 Ormes
Ormes
  • 4,499 posts
Posted 05 April 2019 - 05:51 AM
Can rattle side to side so you add buffers on the edges of the inside of the calipers (4 small strips).
As smiley said, if it is rattling between the piston(s) / disk, it would be sticky piston and/or poorly worn pads, so check the pistons retract and push out smoothly and check condition of pads.
#7 Rickybobby
Rickybobby
  • 27 posts
Posted 05 April 2019 - 08:45 AM
Cheers chaps,
Noise has been there now with new OEM Pagids, m1144 and most recently RS14’s don’t think I’ll try the buffers suggested. You can really here it in this video
https://youtu.be/XLcO5V2dQrA
#8 Rickybobby
Rickybobby
  • 27 posts
Posted 05 April 2019 - 10:11 AM
**do think I'll try the buffers
#9 Johnboyhgt
Johnboyhgt
  • 1,005 posts
Posted 05 April 2019 - 11:46 AM
As a quick test for the buffers drive forward and brake then go into reverse and brake. if you get a fairly loud tap noise when braking in reverse then it only has buffers on the top of the caliper and not the bottom.
Mine was resolved by putting buffers on the bottom.
#10 rhoran00
rhoran00
  • 224 posts
Posted 06 April 2019 - 06:52 AM
https://www.elise-sh...e23e472511f9139
Also check that the above are
A) fitted correctly
B) not knackered
Recently replaced mine and the rattle I've been living with for the last 3 years has finally gone 🙂
