Abs And Mot!
12 replies to this topic
#1 mils
mils
  • 12 posts
Posted 05 April 2019 - 10:14 AM
Hi All, anyone know where i can get my ABS fixed in Hampshire at very short notice.  Completely forgot its an MOT failure and its up in a couple of weeks!  Think its prob a wiring problem - speedo works and car breaks fine (does it actually do anything when it does work...)
Suggestions appreciated...
Cheers! Mils
#2 quimbles
quimbles
  • 760 posts
Posted 05 April 2019 - 10:58 AM
check cables to the hubs, probably not the rear left if the speedo works.  could also check the fuse.
maybe there is a switch/connector for the abs delete at the front that as been knocked off.
#3 mils
mils
  • 12 posts
Posted 05 April 2019 - 11:09 AM
Thanks Quimbles, where can i find the switch/conector for the ABS delete please?  Thanks!
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 05 April 2019 - 11:20 AM
that’s a tricky one as it depends where the owner put it. If there is nothing inside have a look in the front bonnet for unlikely switches or even a key switch usually around the area where the tow eye thing is kept
Edited by christhegasman, 05 April 2019 - 11:21 AM.
#5 hairy
hairy
    Moonlander
  • 5,829 posts
Posted 05 April 2019 - 12:03 PM
Should be around here:
http://www.vx220.org...itch/?p=1823467
#6 mils
mils
  • 12 posts
Posted 05 April 2019 - 12:45 PM
Thanks - will take a look
#7 Ivor
Ivor
  • 1,870 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 05 April 2019 - 01:07 PM
Check ABS not disconnected at the wheel, it's how I turn mine off, you will find if it is when you check the connectors at the wheel
#8 T VXT
T VXT
  • 433 posts
Posted 05 April 2019 - 02:19 PM
If the ABS fault light is not illuminated, it will pass...... :ninja:
#9 rabbidog
rabbidog
  • 194 posts
Posted 05 April 2019 - 03:08 PM
Mines under the bonnet.
#10 mils
mils
  • 12 posts
Posted 08 April 2019 - 08:45 AM
Thanks all.  Light is on unfortuantely.  Will let you know how i get on.
Cheers, Mils
#11 Madmitch
Madmitch
  • 538 posts
Posted 08 April 2019 - 09:12 AM
When my ABS light came on it was the cable into the n/s/f hub broken off at the hub.  Have a feel round the back of the hub for the two little wires.  I managed to solder mine back on, didn't think it would last but that was two years ago and it's still there.  Now have a plan B for if/when they break again.
#12 mils
mils
  • 12 posts
Posted 08 April 2019 - 09:41 AM
Thanks Madmitch, here's hoping - that would save me a morning at the garage and a few hundred quid!
#13 smiley
Posted 08 April 2019 - 10:00 AM
The chances of a broken wire are pretty high.
You can save some money on vx ownership with a jack, a simple toolbox and posting your questions here.
