Gasket Cover Bolts
6 replies to this topic
#1 coldel
coldel
  • 794 posts
Posted 08 April 2019 - 08:22 AM
Very quick question, the bolts on my gasket cover are pretty rusty so have bought a replacement set, before I go about it could the learned folk on here just shout if by doing the following it is a daft idea. I was literally going to remove one bolt and replace with a new one, one at a time. there shouldn't be any problems doing that should there? Its literally a case of going around them one after the other. Also what is the torque setting? I had a quick google and found on a Vaux forum saying 8nm but wanted to check...
#2 Johnboyhgt
Johnboyhgt
  • 1,041 posts
Posted 08 April 2019 - 08:32 AM
Wont be an issue doing that, the torque you quote seems correct - in reality a nip is sufficient.
#3 coldel
coldel
  • 794 posts
Posted 08 April 2019 - 08:33 AM
Super, cheers
#4 sford
sford
  • 1,288 posts
Posted 08 April 2019 - 09:28 AM
Gasket cover = cam cover?
The bolts go through a sort of collar that has rubber around it, just be careful pulling each one out. I had a set that I cleaned but then they went rusty really quickly again. Bought a plating kit and am going to plate them myself when the weather gets warmer.
#5 coldel
coldel
  • 794 posts
Posted 08 April 2019 - 09:39 AM
Sorry yes my bad, I meant the rocker/cam cover - I bought these https://www.ebay.co....ne/382286114941
#6 sford
sford
  • 1,288 posts
Posted 08 April 2019 - 11:02 AM
My bad, should have checked what you had. The turbo is different to the NA and the NA has special ones. You should be fine with those for your car.
#7 coldel
coldel
  • 794 posts
Posted 08 April 2019 - 12:56 PM
thumbsup
