Can we have 1 more fresh log?
Posted 11 April 2019 - 08:56 PM
Posted 11 April 2019 - 09:47 PM
Posted 11 April 2019 - 10:40 PM
I now pushed the plug all the way in til IT clicked and then dragged IT back avsindig the lock. Then i got the correct value and started.
I was going up and down on rpm But at last settled pretty Good But is still running very Rich.
I suddently SAW that the exhaust manifold was getting a little red so i did cut.
Hmmm, sounds like a very bad connection and I would no want to drive that before you have solid connection and the correct vaues. As Smiley said; can you post a new log with only ign. on and one of the running engine?
Posted 12 April 2019 - 07:56 PM
Hi,
I found out that it was probably a layer of corrosion on the contacts in TMAP sensor.
But i still get an error on throttle body it seems.
tried to attach log file but it seems like its to big.
Posted 12 April 2019 - 08:38 PM
latest logs.
http://www.speedster...es/temp/ign.smp
http://www.speedster...es/temp/run.smp
http://www.speedster...s/temp/run2.smp
http://www.speedster...mp/throttle.smp
Posted 12 April 2019 - 10:33 PM
The first section of those logs is still all over the place, but then the last part looks pretty normal.
Log (General tab) shows "No PID's reported"....
Posted 13 April 2019 - 09:43 PM
2 more logs from road testing.
http://www.speedster...s/temp/road.smp
http://www.speedster.../temp/road2.smp
Edited by smiley, 13 April 2019 - 09:43 PM.
Posted 16 April 2019 - 06:56 AM
After what i can see, the car is running normal now.
After som more investigation i found out it had to be corrosion in the tmap sensor.
Thx a lot guys for all your help, I really appreciate :-)
