Tyres
Posted 13 May 2003 - 02:56 PM
Posted 13 May 2003 - 03:47 PM
Posted 13 May 2003 - 11:34 PM
If you could please.I have the code at home and can post it later, if necessary.
Posted 14 May 2003 - 06:43 AM
Posted 14 May 2003 - 07:42 AM
Posted 14 May 2003 - 04:56 PM
http://www.bridgesto...2&fuel=unleaded
You could try and get someone to import them for you ?
Jamie
Posted 14 May 2003 - 06:49 PM
Posted 15 May 2003 - 09:06 PM
Posted 15 May 2003 - 10:09 PM
Posted 15 May 2003 - 11:05 PM
Try Micheldever.
http://www.micheldever.co.uk/
Or was that just in VX sizes sorry?!
Posted 16 May 2003 - 09:59 AM
Posted 16 May 2003 - 11:41 AM
S0 3's been around for ages!
Try Micheldever.
...another one indulging today? ....
Posted 17 May 2003 - 01:37 PM
Posted 17 May 2003 - 07:00 PM
No, if you've got the standard tyres then they are "uni-directional", i.e. they have different tread patterns on the left & right.Can I swap the fronts around to try and even the wear up ?
Posted 17 May 2003 - 07:09 PM
Posted 18 May 2003 - 10:24 AM
Posted 18 May 2003 - 11:13 AM
Posted 18 May 2003 - 12:38 PM
what a load of shite....When I complaind they wern't interested and said it's nearly impossible to change a tyre without some damage being done. Cost me £50 to get it repaired.
this kind of folk should be taken out of business hammered by lawsuits....
any DECENT tyre shop will leave any rim unscathed, but it's best to be present while they are working on it......
Posted 19 May 2003 - 08:42 PM
All 3 types are listed at Bridgestone under E040 code. The VX tyre has a BZ suffix. If you get your supplier to ask for E040BZ, you'll get the correct tyre according to the garage that fitted mine.
You will know it's the correct tyre if it has the code CJC**** stamped in the side wall. If it doesn't, you've either got the Elise tyre or the standard tyre fitted to Scooby's/Evo's, etc.
I'm not sure how much difference it makes which tyre you get in the end, but if Lotus went to the trouble of speccing 2 different rear tyres for the Elise and VX, there must be some difference in performance.
Gary
For the sake of accuracy, not picking a fight, i'm not sure I agree with you on this.
The tyres on my VXT are stamped E040BZ. BUT, so are the RE040 tyres on my wife's Seat Leon Cupra.
Also, I believe the CJC**** code is actually the tyre plant/mould they are made in/the tyre itself batch identifier, not the tyre type. You will note that the CJC**** type mark is a sequential mark like a date stamp that changes from tyre to tyre, not a uniform one like the "RE040" mark.
For info, the front tyre on my VXT is CAD5102, the rear CFE5002, and both offside tyres on the Leon CFE3702.
There is also another mark next to the "E040BZ" mark:
K00001 on the VXT front
T9806 on the VXT rear
K00004 on the Leon front
K00001 on the Leon rear
Note the Leon has 225/40x17 all round, same as the VX rear.
Confused now?!
Posted 19 May 2003 - 09:25 PM
225/40 or /45 ?Note the Leon has 225/40x17 all round, same as the VX rear.
Confused now?!
VX is /45-17......
