Vx220 Brake System
11 replies to this topic
#1 Fredrik andersson
Fredrik andersson
  • 3 posts
Posted 14 May 2019 - 01:21 PM
Hello!
2001 speedster 2.2 - i recently had a small crash (only front clam damage). I was diving in 80 kn/h and the car ahead suddenly slammed the brakes, so i did to just to realize i only had about 50% of the brake power, i realesed and slammed the brakes again with no results, i hit the car infront at like 15 km/h. the car is now in a workshop getting the repairs done and the insurence covers it all but im still stuck with the brake problem. ive read myself to know that the problem could be the original 2 channel abs system that went into whats called ''ice mode'' or that the master brake cylinder has broken somehow.
question 1: any thoughs/exepriences of what coould have went wrong and coused the brakes to not work properly?
question 2: experiences/recommendations on removing the original abs system or uppgrading to a 4 channel abs system?
question 3: upgrading to a 4 pot front brake kit, is it worth it? link to the kit you recommend!
#2 vocky
Posted 14 May 2019 - 02:01 PM
I suffered 'ice mode' in my vx220, so replaced the ABS controller with a 4 channel Lotus version. It's been fine ever since.
4 pots normally have a bigger brake pad surface area so they can reduce the heat build up, thus you don't get brake fade as quickly as the 2 pots
However the vx220 / speedster brake servo vacuum hose does perish over time and this can also cause poor braking.
#3 Bargi
Bargi
  • 4,483 posts
Posted 14 May 2019 - 02:34 PM
Sounds like you may have fallen foul of DRP kicking in, although generally just seen on Track, but def sounds like it
Link here
#4 sford
sford
  • 1,459 posts
Posted 14 May 2019 - 04:28 PM
IMO there isn't a need to change to the bigger calipers for a normal road and a bit of track. It's a nice to have but a lot of the problems seem to come from old fluid and lack of general maintenance.
With regards to the ABS, some people turn it off by disconnecting the front sensor. Some people disconnect all but the rear left. Some people upgrade to the four channel. Just depends on budget I suppose.
Edited by sford, 14 May 2019 - 04:30 PM.
#5 piwo
piwo
  • 178 posts
Posted 18 May 2019 - 06:14 AM
Lotus ABS is big thing and eliminates ice mode. It is very good on track and road. Bigger calipers and brake disc is unnecessary. What's You need is less front power braking and bigger rear power. You can do IT with brake pads which Has better coefficient of friction on rear.
Edited by piwo, 18 May 2019 - 06:16 AM.
#6 Fredrik andersson
Fredrik andersson
  • 3 posts
Posted 21 May 2019 - 04:26 PM
i took the safe route and orderd a 4 channel ABS ecu from a guy named Paul, i will update about the improvements!
#7 900fc
900fc
  • 26 posts
Posted 25 May 2019 - 04:36 PM
Fredrick,
Once tested and if you like it, I would be interested to get the contact and price where you bought your 4 channels ABS module.
Thanks,
Cedric
Edited by 900fc, 25 May 2019 - 04:37 PM.
#8 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 04 June 2019 - 08:33 PM
I run my 4 channel ABS on track and it works perfect.
,Per
#9 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 04 July 2019 - 03:59 PM
Just a comment from my perspective - You still get irritating abs intevention on track with the Lotus ABS unit if you're pushing hard. Also the 4 pot Lotus big brake kit is a complete waste of money unless you address the rear calipers - the brake bias is far to forward prior to fitting 4 pistons front calipers!
#10 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 04 July 2019 - 04:19 PM
I dont
In 1.5 weeks I will test again on a track which is more brake demanding.
But I tested on this track last year, but this year I will push harder.
But since my 4 channel ABS installation I had no issues.
#11 Exmantaa
Posted 04 July 2019 - 10:38 PM
:yeahthat:   It's not that it creates issues, but when pushed hard you feel that it is "doing something" and that I don't like. Switched off things get much better on track. (only front sensor, the rear is necessary for the rear proportioning function)
And indeed the rear needs a bit more bite on track, so I use slightky more agresssive pads there. ;)
#12 Firthy
Firthy
  • 576 posts
Posted 05 July 2019 - 02:07 PM
When your pushing hard in the wet on a track day where you want to drive home, having recently moved to the 4 channel I wouldn't be without its bloody incredible.
I have no issues with it in the dry either you just need to learn how to manage the modulation.
Since going SC where the cars a lot faster in a straight line I find the 4 channel a lot more valuable!
Edited by Firthy, 05 July 2019 - 02:08 PM.
