Injector Pulse Width...
Posted 22 May 2019 - 09:01 PM
First of all, is it... Second of all any idea what sensors of multiplying factors could cause this?
Aiming to chat to SCS tomorrow....
Posted 22 May 2019 - 11:09 PM
We need a bit more info than that...
What ecu, which injectors, which fuel pressure??
But 16-18ms is very high for idle. On 60lbs injectors@3.0 bar static pressure I'm idling at 1.8-1.4ms from a medium warm start...
Edited by Exmantaa, 22 May 2019 - 11:13 PM.
Posted 23 May 2019 - 05:58 AM
I take it you changed the immobiliser chip and ring to match the new ECU?
Posted 23 May 2019 - 08:22 AM
They have a remote conect facility so they have offered to connect in to help diagnose.
Posted 23 May 2019 - 12:14 PM
water temp reading normal? also voltage reading sensible range , both will compensate injector timing , but not by that much
what is the load reading , is map sensor setup?
