Supercharger Water Pump Signal Wire
3 replies to this topic
#1 fredrik J
fredrik J
  • 91 posts
Posted 30 May 2019 - 02:26 PM
Hi,
Have some problems.
I know I should use pin number 8 on the blue X2 connector, white/purple wire to the water pump.
I used white/purple wire but I got no power there for the signal.
someone who knows where pin number 8 really is? finds no numbering 😬
Regards Fredrik
#2 Exmantaa
Posted 30 May 2019 - 04:13 PM
Yep, pin 8, white/violet fuel pump wire from the blue X2 connector.
(although there are VX-ers with diffferent wire colors. Also for the throttlebody wire swap!)
From memory the big 2mm brown/pink wire in the corner is pin1.
In this picture pin 1 is in the bottom left corner. Then you count upwards; #1,2,3,4,5. Then 2nd row, pin next to the big #1 is 6,7,8,9,10.
PS; you do know that it only has 12v a few seconds on ignition  and only powers up when the engine turns over/runs....
Edited by Exmantaa, 30 May 2019 - 04:16 PM.
#3 chris_uk
  • 10,060 posts
Posted 30 May 2019 - 09:36 PM
i always relayed into the existing fuel pump wiring, that way you get the prime function on ignition.
#4 fredrik J
fredrik J
  • 91 posts
Posted 30 May 2019 - 10:03 PM
Thanks for the reply!,👌
I just think i tested with ignition on, so maybe that's what I missed 😅
I'll check this tomorrow, (the battery was discharged today)
Thanks again 😁
