Vxt Engine
7 replies to this topic
#1 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 30 May 2019 - 08:14 PM
Is the engine in an 2008 Astra VXR the same as in a VXT?
Brother is looking at buying an Astra VXR and wondered whether anyone on here had any experience of them and known issues / good / bad etc
Cheers
Edited by ChrisS1, 30 May 2019 - 08:19 PM.
#2 hairy
hairy
    Moonlander
  • 5,829 posts
Posted 30 May 2019 - 08:48 PM
Isn't it an LEH?
#3 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 30 May 2019 - 09:37 PM
Not sure.
Siztenboots can probably answer that.
Think Rusty had one for a short while.
#4 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 30 May 2019 - 10:04 PM
Isn't it an LEH?
Yep.
#5 scw02102
scw02102
  • 1,581 posts
Posted 31 May 2019 - 05:22 PM
Astra VXR is a Z20LEH
Vx220 is a Z20LET
Basically the same but the LEH has stronger pistons and oil squirters.
LEH turbo is better too. Stronger cast and can hold big boost better
#6 Duncan VXR
Duncan VXR
  • 5,273 posts
Posted 31 May 2019 - 10:39 PM
Turbo different but very much the same setup as LET other than points mentioned already
M32 box can have issues but well documented as are usual LET usual points
Check cambelt, water pump servicing, look for oil leaks and poor upgrades areas ;)
Can't commemt on Astra chassis, electrics etc
#7 siztenboots
  • 26,610 posts
Posted 01 June 2019 - 10:59 AM
small differences , the LEH thermostat has a return metal pipe along top of the turbo , rather than the Lotus rubber hose clipped to the bulkhead , plus the obvious stuff powersteering , aircon etc.
which one is better or worse depends on condition
turbo wise both are old units are now superceded
#8 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 02 June 2019 - 11:36 AM
Thanks all.
Greatly appreciated.
