Turbo/manifold Heat Shield Question Need Advice Quick
6 replies to this topic
#1 Steviejay
Steviejay
  • 36 posts
Posted 19 June 2019 - 09:34 PM
Hey people just booked my car in for some work at the local garage, and also noticed my turbo heat shield is flopping about and worn out, really needs replacing.
I noticed it is all over the shop shielding the manifolds, the turbo, there is a lower part too i think.
Is it all necessary ? it's the corrugated type aluminum sheeting stuff that creates a chimney type affair.
Question is can I take all that off and just fit this?
Does the heatshield have to cover all of the manifold lower down and the turbo or will this work?
Not sure how critical it all is but i do know mine is flapping about and broken and it has to go.
i need to sort this asap as only have 2 more days off and them I'm away on a course for a while and then back to drop car in for work.
Its a stage 2 Turbo with VXR Turbo if that makes any difference.
https://www.txautosp...o-z20leh-upra">
#2 Steviejay
Steviejay
  • 36 posts
Posted 19 June 2019 - 09:45 PM
I also have a hard intake pipe made of metal not silicone if that matters.
Is it really just the actuator that needs protection from the heat or is it the actuator intake pipes, and back of the engine
bay or is it fine with just that cover above that i posted.
(seems the images i posted have disappeared but the link works.
https://www.txautosp...old-heat-shield
Thanks guys.
Edited by Steviejay, 19 June 2019 - 09:46 PM.
#3 Duncan VXR
Duncan VXR
  • 5,250 posts
Posted 20 June 2019 - 06:19 AM
The vx uses the heataheilds to also protect various hoses and the bulkhead. It is designed as a chimney drawing air from the undertray up and out the boot vent.
Common issue for the material to fatigue but either repair or replace
Not sure the item in that link will do much on a vx220
#4 Steviejay
Steviejay
  • 36 posts
Posted 20 June 2019 - 07:00 AM
Thanks Duncan,who sells the replacements as I'm desperate to sort this ASAP
Thank you
#5 Duncan VXR
Duncan VXR
  • 5,250 posts
Posted 20 June 2019 - 08:11 AM
http://www.vx220.org...bo-heat-shield/
Few places that will have them but also 2nd hand option and or buy some nibus / style material and copy the broken bits
DG
#6 Talk-torque
Talk-torque
  • 105 posts
Posted 20 June 2019 - 12:42 PM
If you need Nimbus sheet, the guys here:
linky
will give you decent discount, if you ask them nicely! Makes it much cheaper than Semen Squeaks etc.
#7 siztenboots
  • 26,468 posts
Posted 21 June 2019 - 04:53 PM
Thanks guys.
yes actuators get expensive when you keep having to change them due to radiant heat
