Ati Harmoni Balancer
3 replies to this topic
#1 Stig_1911
Stig_1911
  • 118 posts
Posted 25 June 2019 - 02:10 PM
The ATI crank pulley is 8 rib, Even thou their web Page stated otherwise😓 does the ATI crank pulley work with a 6 rib belt, or do I Have to order a costom made 8 rib altenator pulley and use a 8 rib belt?
Best Regards Stig
#2 chris_uk
  • 9,870 posts
Posted 25 June 2019 - 03:22 PM
It would work, the inner rib has to line up with the rest of the system, you will just have 2 ribs unused on the outer part of the damper,. suppose a way to look at it is extra mass your having to turn. so ideally.. you want the correct sized one.
#3 Stig_1911
Stig_1911
  • 118 posts
Posted 25 June 2019 - 03:40 PM
I Ordered the correct one, when i contacted ATI they Said both the pulleys overdrive and underdrive for the ecotec engine was 8 rib, that their web Page were wrong... Already ordered a custom 6 rib altenator, pulley. But if IT works, IT works... Thanks for replying 🤗
#4 The Batman
  • 30,133 posts
Posted 26 June 2019 - 01:14 AM
it will work fine thumbsup
