Vxt Which Air Filter Choices...
Posted 01 July 2019 - 08:44 PM
So I believe I’ve blown my MAF by using a K&N air cone filter, I’ve read on previous posts that the oil in them can ruin a MAF!
So my next question is, I’ve ordered a new MAF and I don’t want to ruin that one, so which air filter is a best for a modified VXT?
Thanks
Scott
Posted 01 July 2019 - 09:03 PM
Off shelf:
Best filtration for a standard car = standard air box / paper filter.
Makes a nice noise and doesn't kill MAFs and said to have good filtration but probably doesn't have the best flow = Apexi
Best filtration & flow Dave H utilising modified OE air box / paper filter
Posted 01 July 2019 - 09:43 PM
i can supply pipercross or ITG if you want
Posted 02 July 2019 - 06:27 AM
I’ll drop you a text ðŸ‘ðŸ¼
Posted 02 July 2019 - 06:34 AM
Off shelf:
It’s not standard, this is why I’m getting a bit confused, I currently have the line filter straight into my MAF. The MAF is an upgraded 80mm one already
Posted 02 July 2019 - 06:49 AM
I still have the huge K&N cone filter set up on mine and it's been fine for many years. I also still have a working original MAF.
I believe a lot of the 'Oiled filters will kill your MAF' stems from when some people service the filters. If they are over oiled, or in the case of the panel filters, oiled from the wrong side, then some of this oil will obviously end up coating the hot wire in the MAF and slowly kill it off.
Posted 02 July 2019 - 08:30 AM
Trouble with oiled filters is its so easy to over or under oil its such a hard to define level and a vague area. Each time I do my daughters ITG its always a pain.
Is there not a filter system other than standard that doesn't need oiling?
Martin S
Posted 02 July 2019 - 08:47 PM
I got Apexi, sounds amazing and is dry so wont mess anything up.Had mine on for 5 years plus also got one on my MX5 turbo too
Always come out on top with various tests, just make sure you buy a genuine one, not ebay fakes
http://www.mkiv.com/.../index.htmlbkbk
Posted 04 July 2019 - 06:10 AM
Apexi here too, been on about 5 years as wellI got Apexi, sounds amazing and is dry so wont mess anything up.Had mine on for 5 years plus also got one on my MX5 turbo too
Posted 04 July 2019 - 07:52 AM
Yes its this. Oiled filters are fine if you do it right and follow the instructions. I used the same K&N filter on my Celica GT4 for 4 years without a single problem cleaned it regularly and by the time I sold the car it still looked immaculate. Always oil the correct side as instructed and all works no problem.
Posted 04 July 2019 - 10:34 AM
Excepted it kill slowly your engine ...
Due to poor filtration capacity !
Posted 07 July 2019 - 10:14 AM
I used Apexi on my sc car.
Martin S
