Vxt Modifications And Mappings
7 replies to this topic
#1 Co220
Co220
  • 41 posts
Posted 01 August 2019 - 07:12 PM
I have VXT for trackday use. I have other cams, larger intercooler, other downpipe, standard turbo etc.
VXRacing changed my software last year and the engine runs great. I'm thinking of upgrading to a VXR turbo and a charge cooler for a bit more action on track. I found out VXRacing stopped doing mappings.
Do I need a new custom made mapping or are there other ways to get the ECU working with these (not too big?) changes?
Edited by Co220, 01 August 2019 - 07:16 PM.
#2 Nev
Posted 01 August 2019 - 07:14 PM
A VXR turbo will barely give any extra puff. Try a K06 turbo (which is very similar to the K04), that will give you 30 to 50 HP more, depending on a few things.
Try Rabid remaps or RND remaps, both are good. RND staff are genuine engineers (as opposed to fly by night remappers).
Edited by Nev, 01 August 2019 - 07:17 PM.
#3 Co220
Co220
  • 41 posts
Posted 01 August 2019 - 07:50 PM
K06 could work with standard internals, thanks for the tip.
Do I need to go to the workshop for a Rabid or RND remap?
Used to work with the OBD Tuner for my SC VX, the turbo stuff is pretty new to me.
#4 Nev
Posted 01 August 2019 - 08:29 PM
Yes it can, but your mapper needs to know to keep the torque down < 350 ft/lbs or your con-rods may bend. The beauty of the K06 is the larger compressor which will keep puffing up to 7000 RPM.
Almost certainly, best to ring them.
Edited by Nev, 01 August 2019 - 08:31 PM.
#5 Co220
Co220
  • 41 posts
Posted 02 August 2019 - 03:46 PM
Thanks Nev, great help.
#6 Ivor
Ivor
  • 2,192 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 02 August 2019 - 05:45 PM
Your VXRracing map, is that Steve's?
#7 scw02102
scw02102
  • 1,581 posts
Posted 20 August 2019 - 07:48 PM
Rabid is now called The Tuning Society and based in Basingstoke, Richard knows his stuff. Will need to be mapped on his dyno.
Oddly two well known tuners said to me no point doing the k06 route unless you run over 300bhp and then you going to have to consider a forged engine.
The extra lag of the k06 wasn't worth it they said but it will flow more top end but a Vxr unit will make 300bhp and spool quicker so don't waste your money, so unless your gonna run big power and torque I wouldn't bother.
I did go for a k04 hybrid 360 bearing and uprated seals for reliability though.
#8 Ivor
Ivor
  • 2,192 posts
    and now bees
Posted 21 August 2019 - 06:34 AM
I'm running the vxr turbo in mine (stage4)
