Hazard Button Vectra-B/omega-B
11 replies to this topic
#1 smiley
Posted 15 August 2019 - 09:24 PM
One of the Dutch got an ebay vectra B hazard button as a replacement.
Turns out vx220 has 7 connections, where as the vectra one has 4.
Is it still a straight swap?
#2 The Batman
Posted 16 August 2019 - 02:05 AM
Why not just try it if he has one lol
#3 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 16 August 2019 - 04:13 AM
Nope won’t work. I have corrected numerous people in the past who have been advised to buy that. I think bizarrely the VX switches pin outs are bespoke on the hazards. The best you are likely to achieve fitting that one is to have to indicate at the same time for it to flash each corner.
#4 Ragged Roy
Ragged Roy
  • 19 posts
  • Interests:VX220, classic Mini, Yamaha R1, Wakeboarding, Kitesurfing, Hairy Pussy/ Maine Coon (cat).
Posted 16 August 2019 - 05:48 AM
I believe this is the correct one. Front would need swapping. https://rover.ebay.c...tm/303068253585
#5 ayresyy
ayresyy
  • 490 posts
Posted 16 August 2019 - 06:37 AM
   Yep, thats the one I used when my switch packed in, very easy to swap the fronts over.
#6 smiley
Posted 16 August 2019 - 07:30 AM
Am i correct to assume now:
- The correct facade part can be found at both vectra b, and omega b.
- The correct 7 pins backend with incorrect facade is only with specific omega b models?
Edited by smiley, 16 August 2019 - 07:31 AM.
#7 ayresyy
ayresyy
  • 490 posts
Posted 16 August 2019 - 12:38 PM
Looking back at my eBay purchase history, the switch I ordered was listed for the Vectra B, but had the 7 pins on it. There were obviously different types fitted in the Vectra for different years/models etc.
#8 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 16 August 2019 - 02:03 PM
I got the vectra-B 4 pin working, you need to wire in two Rectifier Diode 1A (Move black cable shown in photo to top pin)
Photo was when I was testing.
68562383_10157742601429434_2981596413193
Edited by mbes2, 16 August 2019 - 02:10 PM.
#9 smiley
Posted 16 August 2019 - 02:46 PM
Was the facade identical with yours, or did you swap with your old?
#10 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 16 August 2019 - 03:04 PM
They just pop off to swap, so easy
#11 smiley
Posted 16 August 2019 - 03:11 PM
I know.
I am trying to find out exactly what to find on ebay to prevent false advice in the future.
Edited by smiley, 16 August 2019 - 03:12 PM.
#12 ayresyy
ayresyy
  • 490 posts
Posted 16 August 2019 - 04:44 PM
I had to swap it over, about 1 mins work.
