Headlight Lens Sealant + Fitting Method
12 replies to this topic
#1 scw02102
scw02102
  • 1,581 posts
Posted 05 September 2019 - 06:39 PM
Just ordered some new lens whats the best fitment guide?
I'm guessing remove light, cut sealant, clean, squeeze new sealant and fit.
Whats the best sealant?
Thanks in advanced
#2 martinroger
martinroger
  • 459 posts
Posted 05 September 2019 - 06:42 PM
Butyl tape, 4x3mm or 3x3. Squash it. Also called roofing tape
#3 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 05 September 2019 - 11:39 PM
Make sure you oven it first after you stretch it out on the light unit then clamp it in place.
#4 scw02102
scw02102
  • 1,581 posts
Posted 08 September 2019 - 05:59 AM
Thanks guys. Mark I might bell you as know you have taken yours out before :)
#5 scw02102
scw02102
  • 1,581 posts
Posted 08 September 2019 - 07:03 AM
Is this the stuff you fit then put in the headlight into the oven to make it melt into position?
#6 martinroger
martinroger
  • 459 posts
Posted 08 September 2019 - 09:10 AM
Yup, it helps!
#7 Rosssco
Rosssco
  • 4,183 posts
Posted 08 September 2019 - 01:38 PM
Butyl tape for the headlight lens, Sikaflex (or similar - Fezzasus posted a link to the correct stuff previously) for the rear light lens (some of us have lost a rear lens using butyl tape only).
#8 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 08 September 2019 - 07:19 PM
They normally pop off if not stretched and heated up before fitting
#9 ianrm
ianrm
  • 11,097 posts
Posted 26 December 2020 - 09:04 PM
What temperature and how long do you leave them in the oven:?
#10 scw02102
scw02102
  • 1,581 posts
Posted 26 December 2020 - 09:14 PM
60C for about 15-20 min I think.
It’s only warm certainly not hot
Just keep an eye on them so you don’t over heat them
#11 ianrm
ianrm
  • 11,097 posts
Posted 26 December 2020 - 09:21 PM
Cheers
#12 Cavturbo
Cavturbo
  • 387 posts
Posted 27 December 2020 - 10:48 AM
I found that a hairdryer worked pretty well with a plastic scraper type thing to carefully slide between the lense and the light cluster. Replaced the nut on the back with a wingnut to make removal easier which was helpful when Tigerseal failed after my first attempt!
#13 ianrm
ianrm
  • 11,097 posts
Posted 27 December 2020 - 05:50 PM
  It wasn't hard to get the Headlight lens/Cover off as half of it had already come unstuck. I just carefully cut away and the rest with a scalpel. Once removed I cleaned the headlight unit lens. Then I applied Butyl tape to the lens and refitted it. The next step was to leave it in the oven for  mins at 60c. After leaving it to cool for a couple of hours I then sealed the Lens and unit with black silicone. I will leave it over night and re-fit it tomorrow.
A good tip from Cavturbo, which I did 14 odd years ago, was to fit Stainless Steel wing nuts to make removal easy. I did add a bit of Coppercoat as well to stop them seizing.
