My pump/sender unit is a little bit totally buggered.
Where can I get an OE pump/sender?
Presumably they are a standard unit, what do/did they fit?
(I am aware there are various "uprated" units available but I am not looking to pay £300+ for a fuel pump for a road-only car)
78635342_10162850983220714_1576641460244054016_o.jpg 223.22KB
15 downloads
Source For Standard Fuel Pump/sender Units? (2.2 Na)
Posted 08 December 2019 - 05:07 PM
Posted 08 December 2019 - 05:35 PM
Any used ones will be a risk I would just get the Spitfire its a fit and forget and even good to stay in there of you Supercharge later.
Posted 08 December 2019 - 05:48 PM
Posted 08 December 2019 - 06:06 PM
i have a S1 pump that you should be able to do some parts swapping to make one good one if you want
Posted 08 December 2019 - 07:06 PM
I'll explain a little further...
The car is already known by some - it has 19k miles on the clock and had been stored in a (probably damp) garage for 14 years - hence the inside of the tank is now full of rusty crap.
I removed the sender/pump unit because the fuel level was permanently showing empty.
I wont be turbo/SC ing it, as to retain its value, the car needs to remain stock.
The tank itself doesnt leak, so I will remove it, flush it and line it with tank liner juice (Which I have on both my Lotus Elan and Lotus Esprits in the past)
The pump actually works(!) but its definitely not going back in the tank.
The level arm had seized in place at the bottom, hence the low reading, I cant get it to move freely, otherwise i would keep it and just replace the pump itself.
I am not going to fit an uprated £300+ part if i don't need to - surely the sender/pump cartridge must have been standard fitment on a production car of the era?
Sorry, I'm not getting irate!!, I am just not the type to "throw money at a problem" without exhausting all other options first.
Edited by Mandarin Pete, 08 December 2019 - 07:08 PM.
Posted 08 December 2019 - 07:07 PM
Interesting... Does it have a working level arm?
(Is the S1 part similar?)
Posted 08 December 2019 - 07:18 PM
Posted 08 December 2019 - 07:22 PM
A second hand tank might be less money than your tank liner juice...
£17.
And I would line a used tank anyway.
Edited by Mandarin Pete, 08 December 2019 - 07:22 PM.
Posted 09 December 2019 - 08:17 AM
Posted 09 December 2019 - 09:07 AM
Didin't JG put a compleet lotus unit in his VX at some point?
Posted 09 December 2019 - 09:13 AM
Think new lotus or modified versions will be best option given the age of the car.
What's the rest of the car like ? Bushes etc
Posted 09 December 2019 - 06:43 PM
(I am aware there are various "uprated" units available but I am not looking to pay £300+ for a fuel pump for a road-only car)78635342_10162850983220714_1576641460244054016_o.jpg
That's probably the worst I have seen and that's several hundred.
No, they are not a standard unit, very unusually they were made for Lotus by Delphi, now obsolete due to the terminal block melting.
Posted 11 December 2019 - 05:20 PM
There are no components from the S1 OE pump which will fit an OE S2 pump.
Well. I suppose you could cut the plastic pipe off and some of the wires to use but I don't think it will help much
Posted 11 December 2019 - 09:25 PM
Fez found it I seem to remember.
Posted 11 December 2019 - 10:51 PM
The model spitfire uses is quite generic.
Search for acdelco MU series and you will see a very large amount of units very close to it.
Most actually not far off spitfires price.
Posted 14 December 2019 - 04:07 PM
Well they may look generic, especially the online images which are generic
but a few variables...
D of the canister otherwise it will not fit into the tank
D of the top otherwise it will not fit into the recess
Seal type and dimensions
fuel spigot size
Canister height otherwise it will either not touch the bottom of will not comprises enough to fit
sender unit ohm range
sender unit arc
sender unit type 3/4 wire
sender direction
sender arm length
The 2 important ones are the flow/pressure graph and the refill capability, the only way to get this is by testing. Remember some of the pumps are for carbs and are very low pressure, none are HP, they are a special order.
Most cars have a compact tank so refill rate is not important and often poor, for the S2/VX tank it is critical.
There are about 30 units which will fit the aperture correctly, as for the rest
As for pricing the HP pumps we sell are actually cheaper than the OE ones when they were available (they are not great by modern standards nor E85 compatible).
I'm sure the US supplier will love to hear from you regarding any fitting issues and warranty returns etc
Posted 14 December 2019 - 11:23 PM
In the end it is not important what base you used.
You spend time on R&D on making something work on our cars where vauxhall/opel do not care anymore, and you ask a reasonable price in my book.
I'm a happy customer.
Topicstarter may need to look for a unit that was replaced with one of yours, and swap just the pumpunit for a new one and be done with it.
I cannot think of anything else on a budget.
Posted 15 December 2019 - 08:18 AM
Another option is to eliminate the OEM pump config. Simply replace it with a time tested Bosch 044 pump, a good place to mount it is on top of the existing tank hatch. It will deliver strong pressure and last a long time.
Posted 15 December 2019 - 10:15 AM
If the OP doesn't need the output from a HP pump then a 044 is not really the solution.
It will circulate the contents of a 50% full tank around the warm/hot engine bay and back through the FPR and into the tank about 10-15 times per hour.
Now add all the pipes, junctions, external filters, new wiring etc*
Without the OE unit you have no recharge either? or are you saying fit both pumps? i.e 20 amps of pumps?
This is not thread particular btw, I have posted many times over the years regarding over fuelling issues (usually vapour lock) and the wisdom of joins and junctions in fuel lines within the engine bay.
The best place for the pump is in the fuel tank as it avoids pre turbine cavitation, freely cools and is OE quiet.
Posted 15 December 2019 - 10:32 AM
It's a fairly simple install really, not much harder than the 6 hours I wasted fitting a new OEM type pump in the canister in my tank. Hot fuel and vapour lock don't affect me at all, even if I'm just chugging round for 3 hours at 2000 RPM in the summer.
