Avon Zzr Vs Advan A052
Posted 10 January 2020 - 02:43 PM
did anyone compare this two tires on the track? which faster. what are your feelings.
Posted 10 January 2020 - 05:09 PM
I like the 52, but never tried the ZZR.
Posted 10 January 2020 - 05:37 PM
Yeah, I was gonna say the only 2 people I know to have tried them is Coco and JG.
Posted 10 January 2020 - 06:18 PM
Are you doing your best laps on them ?
Posted 10 January 2020 - 06:40 PM
If you have used 888R? I would say grip of 888R is slightly better than ZZR.
All other attributes I would say ZZR is better : turn in/sidewall stiffness, endurance and wear rate.
Probably not much good...you now need someone to compare 888R against A052!
Posted 10 January 2020 - 07:10 PM
I have read many very positive reviews about a052 but I would like to make sure that they are doing good in vx220.
https://www.trackday...-thread/&page=1
Edited by piwo, 10 January 2020 - 07:12 PM.
Posted 11 January 2020 - 09:41 AM
I race my Caterham on AO48’s and they keep putting in the lap times right down to the canvas (although warm up time increases but that’s not a problem for track days).
If the price was similar I’d go for the Yoko’s.
Posted 11 January 2020 - 11:47 AM
Posted 11 January 2020 - 01:33 PM
Posted 13 January 2020 - 06:14 AM
well described here
https://www.lotustal...h.466020/page-4
I can confirm now that the A052s are faster than the R888Rs. Our local track washed away in a flash flood earlier this summer and they luckily rebuilt quickly .
Got out on track for the first time since running with the R888Rs last season, which my best time posted was 1:07.5.
I knocked a full second off that time almost immediately, 3 laps into the first session, and followed it up with multipl 1:06's. Then knocked another full second later that day as I settled in.
The alignment is worse than it was too, I have to keep the front end of the car higher than it should be to clear the front tires with the very aggressive offset that the wheels have. So I think there's another 1.5 seconds to be had likely too.
The G Meter on my fastest lap with the R888Rs was 1.1 sustained and barely touched 1.2G in one corner versus the 1:05 lap where it's 1.2-1.3 sustained and touched 1.4G
Fastest Lap with the A052s:
Posted 20 January 2020 - 07:28 PM
195/50r15
R888r vs zzr vs ar1:
1) Ar1: 2m24,28s
2)zzr: 2m24,80s
3)r888r: 2m25,26s
https://lm.facebook....ADduERxVb1DAnfw
Edited by piwo, 20 January 2020 - 07:29 PM.
Posted 21 February 2020 - 05:22 AM
Posted 21 February 2020 - 01:54 PM
Do you have any information about the michelin pilot sport cup 2 ???
Posted 21 February 2020 - 03:00 PM
Co do zzr a64 i cup2 na deszczu to chyba bardzo podobnie się zachowują. Avon 7mm głębokości a cup2 5,5mm ale na deszczu na mokrej jezdni całkiem podobnie. Da się z nimi żyć.
Więc jakbym ja miał wybierać między zzr a64 a cup2 wybrałbym zzr na tył i cup 2 na przód.
Edited by piwo, 21 February 2020 - 03:09 PM.
Posted 22 February 2020 - 12:57 PM
well described here
Fastest Lap with the A052s:"
new tracks are generally faster anyway, look at Croft lap times, 1'34/35 before the resurfacing and now cars are 1-2 seconds faster on the same tyres.
i ran ZZR's on a couple of trackdays and found they took quite a while to warm up, but when they did they kinda stayed good and never went off in the 20 or so mins i was on track, but the ultimate grip level was lower than that of the 888's i had previously, the problem with the 888's were they warmed up fast then started to slow down the hotter they got.
Posted 15 July 2020 - 04:22 AM
has anyone already compared advan a052 to avon zzr a24 or zzr a64?
Posted 21 July 2020 - 06:24 PM
Edited by techieboy, 21 July 2020 - 08:27 PM.
Posted 22 July 2020 - 06:02 AM
Posted 13 August 2020 - 04:30 PM
Posted 24 August 2020 - 12:33 PM
Reviews seem to show brilliant results when used on the lotus setup and is offered by Lotus as OE on there latest cup cars.
