Can any advise on where I can source a new wire that tensions the fabric roof
many thanks
Posted 20 January 2020 - 06:09 PM
many thanks
Posted 20 January 2020 - 06:13 PM
Posted 20 January 2020 - 07:27 PM
You have 2 options available.
OEM lotus.
https://elise-shop.n...ster-p-474.html
(Or lookup the part on the DeRoure website)
Or an aftermarket from ElizP.
http://cgi.ebay.co.u...em=201607612470
The aftermarket is stronger and should live longer, but as you can see in the design has metal parts that will touch the rubber of your front and rear seals.
It could potentially scrub on those.
I will leave it up to you which is the most important. Either case the job is a pita.
Here is a how to.
https://wiki.seloc.o...oken_roof_cable
In my case i went to the dyi shop and got a 1 meter threaded rod that fitted exactly on the adjuster, and pulled in the new cable that way.
Easy peasy with that.
Edited by smiley, 20 January 2020 - 07:29 PM.
Posted 20 January 2020 - 08:00 PM
Posted 20 January 2020 - 08:20 PM
OEM lotus.
Here is a how to.
Posted 20 January 2020 - 09:04 PM
Magnets don't help to guide the wire?
My educated guess would be that you never did this job......
Posted 20 January 2020 - 09:11 PM
Posted 20 January 2020 - 09:32 PM
Yes stainless.
The part where the wire goes through has 2 stiching lines.
Sometimes you have to take one out to be able to run it through. It is really right.
Posted 21 January 2020 - 09:14 AM
Liz Pennington ElizpartsCan any advise on where I can source a new wire that tensions the fabric roof
many thanks
many thanks
Posted 28 January 2020 - 10:41 AM
There is another option...
Mine had broken off where the cable goes into the end fitting that doesn't rotate (if you see what I mean - one end has a threaded fitting that can rotate to adjust the tension, the other end is fixed).
I bought (from these folks: https://www.gsproduc...-wire-rope-swr/) a length of 1.5mm stainless wire, coated with clear PVC, a crimp tool and a load of ferrules.
For the fixed end I just replaced the fitting with a crimped loop.
For the rotating end I turned down a copper end stop to make it the right diameter then crimped it on, in the same way that the old wire had an end stop on it to allow the rotating threaded barrel (which I reused) to rotate.
I turned down the copper end stop by holding it in the chuck of a drill and rotating it against a file.
I didn't have any issues feeding the wire through the channel, because I fed it through before crimping the final fitting on.
Way easier than messing about feeding big fittings through a narrow channel and having to unpick seams etc.
Hope this helps
Nick
Posted 28 January 2020 - 04:07 PM
Posted 07 February 2020 - 09:42 AM
Many thanks for all your help
alan
