Setting Up Itbs For Mapping.
Posted 21 January 2020 - 08:36 PM
Don’t think there is an issue, but wondered if it was out would it up set the whole mapping? My thoughts were that it will only affect idle and early opening of throttle, rather than the mapping, so could always be done later if it was an issue.
Posted 21 January 2020 - 08:51 PM
Posted 21 January 2020 - 09:10 PM
Posted 21 January 2020 - 11:42 PM
Posted 21 January 2020 - 11:44 PM
Posted 22 January 2020 - 09:24 AM
Is there an echo in here?
Good luck with the mapping Mat. Hope you keep the love for your car - you’ve worked hard to get to here!
Posted 22 January 2020 - 06:56 PM
Posted 23 January 2020 - 09:09 AM
so every year i have to rebalance the ITBS. thankfully no longer the TPS! generally the idle falls down and the engine isn't as smooth on small throttle inputs (as above)
i have always tried to get them around 5.5 on the air metre.
So does it really matter what the air reading is? (within reason of course) as i had always though this would effect the air/fuel ratio throughout.
However it only effects on low inputs of throttle and once the valves are open it doesn't matter so much?
