Engine Cover
39 replies to this topic
#1 martinf
martinf
  • 145 posts
Posted 11 February 2020 - 01:45 PM
Hi, Looking for a Vectra 2.2 Engine Cover to fit my NA. Anyone have one for sale please?
#2 martinf
martinf
  • 145 posts
Posted 13 February 2020 - 08:09 AM
OK, I guess they're like hen's teeth then - Anyone know what the Vauxhall Part Number is ? - perhaps I can get a new one.
#3 coldel
coldel
  • 1,183 posts
Posted 13 February 2020 - 09:08 AM
What does it look like? Type 'Vectra 2.2 Engine Cover' into ebay and quite a few options pop up?
#4 chris_uk
Posted 13 February 2020 - 09:11 AM
https://z22se.co.uk/...8421-jpg.25311/
#5 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 13 February 2020 - 09:13 AM
Eww 😷
#6 coldel
coldel
  • 1,183 posts
Posted 13 February 2020 - 09:43 AM
I had one of those on my old NA, did a great job of keeping water off the main body but the engine got pretty hot under there, that I took it off when driving. Think I threw it away in the end.
#7 martinf
martinf
  • 145 posts
Posted 13 February 2020 - 09:51 AM
Umm- Thanks for the feedback about heat retention, there seems to be conflicting comments regarding this.
#8 martinf
martinf
  • 145 posts
Posted 13 February 2020 - 11:10 AM
Chris, what's your experience of the cover, did it effect the engine temp at all?
#9 coldel
coldel
  • 1,183 posts
Posted 13 February 2020 - 12:27 PM
I didn't do anything scientific by any means, the temps seemed a bit up when using it. But in all honesty, there are two vents above the engine to I presume, vent heat. If you cover the engine right below those vents there will be an effect. Your engine is unlikely to explode or anything but I really couldnt see the point of it and binned it off.
I guess it beggars the question, what do you want one for?
#10 martinf
martinf
  • 145 posts
Posted 13 February 2020 - 02:13 PM
I'd like to keep the water out of the engine bay and away from the wiring, specifically the ECU
Sent from my LG-H990 using Tapatalk
#11 coldel
coldel
  • 1,183 posts
Posted 13 February 2020 - 02:33 PM
I presume that the car was designed this way expecting water to come in through the vent though? Not sure I remember reading any problems of water causing ECU problems? Mine is sat outside all year round and runs fine.
#12 quimbles
quimbles
  • 760 posts
Posted 13 February 2020 - 07:08 PM
Coil pack went In the recent storm. While car was abandoned outside. Bin bag blew off doh
Drying it out wondering if it still works.
I used to also get corrosion in the crank sensor.
Edited by quimbles, 13 February 2020 - 07:08 PM.
#13 martinf
martinf
  • 145 posts
Posted 13 February 2020 - 07:20 PM
I'm sure that keeping water off the top of the engine along with all the electrical gubbins thats sits nearby must be a benefit, the only downside could be a negative impact on cooling, but there doesn't seem to be any clear conclusion whether this is the case, or not.
#14 quimbles
quimbles
  • 760 posts
Posted 14 February 2020 - 09:03 AM
Driving around never had any issues even in downpours.
Used to use a spare bit of nimbus over the engine when standing outside. But a bin bag works just as well......unless Ciara turns up.
#15 coldel
coldel
  • 1,183 posts
Posted 14 February 2020 - 09:24 AM
Had two VXs now never had a problem with water on the engine and mine live outside 24/7
#16 martinf
martinf
  • 145 posts
Posted 14 February 2020 - 10:13 AM
Ok, thanks a lot for you feedback.
#17 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 14 February 2020 - 10:49 AM
Hopefully said while touching wood!
#18 coldel
coldel
  • 1,183 posts
Posted 14 February 2020 - 11:24 AM
I'm made of wood!
#19 MWS
MWS
  • 1,229 posts
    Cars - VX220s
    Basketball - Miami Heat
Posted 14 February 2020 - 04:11 PM
I have an engine cover on mine and wouldn't be without it if i'm honest. Had an issue with my coil pack on my old VX after a heavy downpour so for the sake of about £30 it was well worth it.
Not had any issues at all with engine heat.
#20 martinf
martinf
  • 145 posts
Posted 14 February 2020 - 05:12 PM
Look out, storm Dennis is coming, anyone without an engine cover had better find some old bin bags and a handful of bricks 😊😊
