Visual Inspection Of Toe Links
7 replies to this topic
#1 coldel
coldel
  • 1,183 posts
Posted 16 May 2020 - 04:59 PM
I am now completely paranoid about them haha.
Will splash out on a set soon but wanted to know, is there a way with the wheels in place of checking them? I can see them in there - should I be wiggling them? Knocking them? What?  :blush:
#2 smiley
Posted 16 May 2020 - 05:22 PM
The wiggle is only good for detecting play.
For actual wear and tear on the famous bolt at the hub, you will have to take it out.
Better safe then sorry. One second you are having fun, and the next you are driving into a ravine.
#3 pete-r
pete-r
  • 2,771 posts
Posted 16 May 2020 - 05:33 PM
Metal fatigue isn't going to be apparent unless you X-ray the parts.
#4 scw02102
scw02102
  • 1,581 posts
Posted 16 May 2020 - 05:38 PM
Just get them changed soon as you can and don’t push it too hard through the corners until then.
They tend to fail when a car has been tracked or fail on track when under high loads.
You car was Adams old one? If so he never tracked or killed it in the corners so should be safe in a straight line.
Still worth changing for piece of mind as when they go you crash lol
#5 chris_uk
Posted 16 May 2020 - 06:02 PM
let me know if you want Spitfire ones :)
#6 coldel
coldel
  • 1,183 posts
Posted 16 May 2020 - 06:54 PM
Yeah Adams one, I haven’t driven it hard and don’t track it but will be looking for something soon. BOT were looking for strong money to fit it and geo (£300) not sure who else to get quotes from around me (Surrey)
#7 FLD
Posted 18 May 2020 - 07:55 AM
From what I've seen over the past few years are people putting a spanner on them and moving the bar on the joints to ensure they're all free moving with no play.  When I first got mine people were seeing boot failures resulting in the ball becoming stiff (ooeer) and then subsequent failure.  More recently it seems to be flex / fatigue related cracking in the treads of the joints.  The later one is more difficult to examine.  You can X-ray of use penetrant dye testing but both are a little excessive.  Just replace them periodically and treat them as a service item.  I did this for a few years before buying spitfire links (FAR superior!).
£300 isn't bad for new toe links and a geo; in fact that's pretty good.  Links are well north of £100 each and, if it's just the joints, they're north of £20 each.  Add a geo on and it looks a good price.
Whatever you do, no option is fit and forget.  Aftermarket ones should be inspected at least annually IMO.  If you're tracking it I'd do a before and after check along with a nut and bolt check (yes, I'm paranoid).
#8 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 18 May 2020 - 08:53 AM
Don't forget to change the HCBs too!!
:grouphug:
