Engine Earth
15 replies to this topic
#1 ukcat
ukcat
  • 390 posts
Posted 31 May 2020 - 07:04 AM
Hi im after a pic of a vxt around the drive shaft heat shield. I think there is an engine earth conection onto the engine block but wanting to see exactly where and how it attaches. Any help would be very much appreciated
#2 Ivor
Ivor
  • 2,216 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 31 May 2020 - 11:20 AM
Picture from above or below?
#3 ukcat
ukcat
  • 390 posts
Posted 31 May 2020 - 01:26 PM
Hi probably above if possible
#4 ukcat
ukcat
  • 390 posts
Posted 31 May 2020 - 01:30 PM
Just wanting to see how and where the spade bolts to the engine block (is it the bolt that hold the drive shaft heat shield to the block)
#5 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 31 May 2020 - 08:09 PM
I'll try and remember to take a pic tomorrow morning first thing
#6 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 01 June 2020 - 09:18 AM
Just looked, nothing obvious to see on mine, all very tight, looking offside yes?
#7 ukcat
ukcat
  • 390 posts
Posted 01 June 2020 - 09:56 AM
can you see if the earth spade attaches to the engine block around the area where the heat shield attaches
#8 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 01 June 2020 - 11:16 AM
I take another look but I can't see anything down there, too much stuff in the way, mines stage 4, not sure if any additional pipework is obscuring the view
#9 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 01 June 2020 - 01:24 PM
I took another look, can't see anything resembling spade connector or an earth wire/strap, can you send me a picture of where you're looking?
#10 ukcat
ukcat
  • 390 posts
Posted 01 June 2020 - 06:15 PM
Ill try and grab a pic but basically the loom runs to the starter motor and then on to the alternator but about 3 inch after the starter motor conections a tee runs off with a spade on the end
#11 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 02 June 2020 - 10:52 AM
I can't see anything down there from above, sorry
#12 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 02 June 2020 - 11:27 AM
I just had a look and can't see anything from the top either (standard tubby engine)
#13 ukcat
ukcat
  • 390 posts
Posted 02 June 2020 - 01:00 PM
Hi you would not be able to see from the top. Looking from under the car there should be a bracket fastened to the bottom of the inlet manifold, this holds a small plastic vacume vessel. The bracket also bolts to the bottom of the cylinder block (just above where it meets the upper sump pan) i think the earth bolts to the same bolt i.e the one that holds the bracket to the block
#14 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 02 June 2020 - 02:04 PM
You did say above! My undertrays are on so cannot see from below,
Edited by Ivor, 02 June 2020 - 02:04 PM.
#15 ukcat
ukcat
  • 390 posts
Posted 02 June 2020 - 02:12 PM
sorry i sort of meant above the undertray but kind off lower down like under the inlet manifold if its possible to see. The position is just next to where the drive shaft heat shield attaches to the engine block
#16 Ivor
Ivor
  • 2,216 posts
    and now bees
Posted 02 June 2020 - 03:39 PM
Can't see anything from above
