Hjs Cat For Sc
Posted 25 July 2020 - 07:41 AM
I replaced it with a 100cell motorsport cat (can't remember the brand maybe red something?) about 4 years back but has recently failed with very high CO at idle, so assume this is the cause.
Ive checked the voltage of the first lambda sensor on opcom which is in the right area so assume this is ok.
I plan to replace with an HJS cat which i obviously should have done in the first place, but I'm not sure which one to get, does anyone know? May go for 200cell this time round as well.
Usually I'd get under the car and measure it but I barely get time for a sh*t at the moment with family life!
Thanks
Dan
Sent from my G8441 using Tapatalk
Posted 25 July 2020 - 08:38 PM
when i bought my 200 cell HJS cat a couple years ago it was £450.
Posted 26 July 2020 - 12:12 PM
Posted 26 July 2020 - 03:32 PM
Speak to Miltek as far as im aware they are the only UK supplier of the HJS cats.
Posted 26 July 2020 - 03:36 PM
Posted 28 July 2020 - 07:44 AM
I bought mine from 2bular. It's 100 cell HKS but this was quite some time ago. Far better than the crap one tullet supplied.
Posted 28 July 2020 - 07:57 AM
These are the markings on the hjs that Tullett welded in on my cat.
I have not fitted it yet, but i take it it fits.
Posted 28 July 2020 - 08:06 AM
Posted 28 July 2020 - 08:52 AM
Only just noticed that this number gives nothing usefull in google.
Posted 28 July 2020 - 09:16 AM
Posted 28 July 2020 - 11:03 AM
These are basically the 200CPI cats:
https://www.hjs-moto...-catalysts.html
Get a cat that's as big as possible for you to fit diameter-wise. 120 or 130mm preferred.
The 'HD' ones are heavy-duty and usually better for forced induction car exhaust temperatures.
I've been using the type 90950161 for several years on my N/A K20 Elise (200cpi, 120mm diameter, 300mm total length):
And ECE R103 marked for those that need it. I thought it was no longer available, but seems some still sell it:
https://dbilas-shop....00cpsi-oe60.5mm
Works fine and very good MOT exhaust gas values like 0.01% CO and such after a little warmup.
HJS ones are not cheap, but they are the 'real deal' as far as build quality and lifespan goes. Do make sure to buy from a reputable reseller as like many things these days there's a lot of counterfeit ones out there too..
Bye, Arno
Posted 28 July 2020 - 11:07 AM
Posted 14 September 2020 - 05:47 AM
The hd one wasn't available at the moment and from what it says on the website the difference is just a different winding of the structure which enables a later euro 4 level.
Thanks for the help as always
Posted 14 September 2020 - 06:26 AM
The hd one wasn't available at the moment, the website said the difference is the winding of the cell structure which enable a later euro 4 spec, no mention of higher durability.
Thanks again for the help
Posted 14 September 2020 - 06:30 AM
The hd one wasn't available at the moment, the website said the difference is just the winding of the cell structure which enables a euro 4 level, no mention of higher durability.
Thanks for the help.
Note.. if you put a greater than symbol in the text it doesn't load any further text in the post using tapa talk?
