As title I would like to remove the rear panel that the speakers mount to as I wish to put better speakers in plus cables etc, if I removed it will be a lot easier to add the amp/crossovers.
Do I need to remove those strange headrests as well, if so how does the front come off is it just a tug or are there secret bolts somewhere just waiting to fâ€â€k up your day.
Rear Head Rest Panel Removal
Started by
wilksy
, Aug 01 2020 07:23 PM
2 replies to this topic
Posted 01 August 2020 - 07:23 PM
Posted 01 August 2020 - 07:37 PM
The headrests can stay.
Both seats need to come out.
The rear panel depends a bit if it has ever been removed before.
If not, it is stuck on with double sided tape from hell.
Depending on what you want to do with the amps, you could leave in the rear panel in place, bolt in new speakers, then place you amps where you want.
Unless you want to hide them behind the panel?
Posted 01 August 2020 - 09:09 PM
Cheers seats are already out for weekend cleaning wk4 (it was very dirty) I want to take out the panel to run the power cables, the centre sections are out awaiting carbon replacements to I will run the cables using the same path as factory.
