Abs Unit , Top Part The Kelsey Unit Part
abs unit
9 replies to this topic
#1 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 02 August 2020 - 12:32 PM
As above needed as mine has failed , Kelsey unit it's called .
#2 smiley
Posted 02 August 2020 - 01:24 PM
Get a picture of the exact type number up.
Iirc turbo is different from na.
#3 aquilaproejct
aquilaproejct
  • 267 posts
Posted 02 August 2020 - 11:14 PM
G'day mate... Been awhile. What's the failure mode? Mine died as well, gotta a replacement but cracked her open and repaired it fairly easily.
#4 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 03 August 2020 - 07:17 AM
Actually checked them both there the same .iv swapped the top of the abs unit on the turbo I have for the broken 2.2 I have . It's sorted but got get a replacement .👍🏻
#5 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 03 August 2020 - 07:20 AM
Wow how's it going ? Long time !
It wouldn't let the machine read the code so guess it was the top off the abs unit an was right . I' don't fancy cracking it open unless it's easy ?
How sad the vx since it left the uk from mine ??
#6 aquilaproejct
aquilaproejct
  • 267 posts
Posted 03 August 2020 - 10:32 AM
Mine was causing speedo not to work but no codes, no abs light. It requires some careful cutting of the top cover off and with a bit of solder just touching up a couple of solder joints. Cars good, been on track a few times, supercharged it.
Then in our first quarantine completely stripped and rebuilt suspension, replacement steering gear and I shaft and re-trimmed seats. Now in quarantine #2.. so stripping wheels to repaint them...
Got any hardtops floating around?
How you keeping?
#7 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 23 August 2020 - 08:09 PM
How you keeping?
glad your loving the vx mate .,, iv sold a lot to Europe but never to were you live mate ..
How did the armendffend come off in the end ??
Have show us a pic
#8 Gopherit
Gopherit
  • 77 posts
Posted 03 September 2020 - 01:17 PM
I have a working Kelsey Hayes unit from my VX NA (SC) - came off 2 years ago when I went 4-Channel.
£100 plus postage?
Paul
#9 Baloo
Baloo
  • 87 posts
Posted 27 January 2021 - 04:23 PM
Paul, the speedo has stopped working on my NA. Been told its the ABS unit. Will your KH unit correct my issue?
Thanks, Steve
#10 smiley
Posted 27 January 2021 - 04:45 PM
speedo is linked to rear left abs sensor.
If that does not workm speedo does not work.
