Hot Boot Relays
15 replies to this topic
#1 VX DAVE
VX DAVE
  • 139 posts
Posted 02 August 2020 - 07:53 PM
Just after some technical advice
My boot relays are getting quite warm, if not hot
yellow seems fine but the two grey ones are quite warm
is this normal ?
VXT
T I A
Edited by VX DAVE, 02 August 2020 - 07:53 PM.
#2 fezzasus
Posted 02 August 2020 - 09:22 PM
Fuel pump and ECU relay, so will be always on and running 30 A when the car is running so not surprising that they get hot
PS. shouldn't one be brown?
Edited by fezzasus, 02 August 2020 - 09:23 PM.
#3 chris_uk
Posted 02 August 2020 - 09:25 PM
the ECU one is usually brown.
#4 smiley
Posted 03 August 2020 - 07:04 AM
Does your ubend still have the oem heatshield, or heatwrap, as that is just below your relay location.
#5 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 07:29 PM
I did a search before posting and one of the answers I found suggested that the VXT has 2 grey relays,  something to do with the normally open and normally closed switches
Posted 30 March 2018 - 03:46 PM
brown relay switches two circuits - 2 x Normally Open contacts
grey relay switches one circuit - 1 x Normally Open and one x Normally Closed contacts
Looking at the vxT engine wiring diagram it shows K16, K18 and K62 as single switch, so grey relays can be used.
#6 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 07:30 PM
Probably not,  I have a Milltek system fitted
#7 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 07:55 PM
Looks like it gets too warm.......
#8 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 08:10 PM
Not sure what the numbers mean exactly, but the brown relay has numbers, 30/40A  and the grey relay has 20/30A
The diagram on both relays are the same
#9 smiley
Posted 04 August 2020 - 08:21 PM
Is it the crispy one that is supposed to be brown?
Edited by smiley, 04 August 2020 - 08:21 PM.
#10 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 08:23 PM
I think so,   my fuel pump kept stopping when these got hot
I have been looking at the brown relay and I can see the brown relay appears to have a double switch,  so my post above is wrong
#11 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 08:26 PM
top diagram is grey
#12 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 04 August 2020 - 08:28 PM
The grey bosch relays can also be found under the front bonet so you can swap the one for the horn for example as a temporary fix.
The brown one in the 2.2 has two outputs.
#13 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 08:34 PM
Any info regarding the VXT boot relays
#14 smiley
Posted 04 August 2020 - 09:19 PM
Difficult.
I tried to get a clear picture of the 4 relays, and ended up with 3 completely different results.
Not sure what is going on with this turbo stuff. None of them have the brown one like the NA.
#15 VX DAVE
VX DAVE
  • 139 posts
Posted 04 August 2020 - 10:02 PM
I have found the wiring diagram on one of the speedster forums,   the wiring for them shows single switch relays in K16 and K18
#16 Arno
Arno
  • 1,238 posts
Posted 05 August 2020 - 09:00 AM
If the pins got so hot you may want to check/replace the contacts in the relay socket too.
These 'springy' female contacts tend to relax when they are overheated and afterwards they can have issues making good contact even on a new relay and you end up burning it more from the resistance in the connection. (until the plastic of the plug simply melts away in a charred blob..)
At a minimum clean the socket well with a contact cleaner and check if the contacts still grab the relay pins securely. If not, pull the contact out of the socket and gently squeeze it a little in some pliers and re-test.
It's not a perfect fix as the conmtact material tends to have softened, so it has lost some of it's spring-back and will have a weaker grip, but often it works for some time again.
