Just wondering if anyone has a copy of a full pinout for the Delco ECU used on the 2.2 please?
Z22Se Delco Ecu
Posted 15 September 2020 - 06:59 AM
Posted 15 September 2020 - 08:51 AM
Posted 19 September 2020 - 04:37 PM
Looking to wire up and activate the cruise control to help with my sciatica on longer journeys. I have done it on the turbo before, but not the N/A. The link obviously doesn't show all of the ECU pins (only the VX220 relevant ones). I have just managed to find a pinout from the Z22SE Astra G now, so this should point me in the right direction.
I'll update once/if its working! Not sure it this has been done on the N/A before?
Posted 19 September 2020 - 09:45 PM
Posted 19 September 2020 - 11:06 PM
Hey mate. Spent some time on this myself. The problem is the ECU software does not have the bit of code in there for cruise control..it seems they stripped it out if the NA software... But not the turbo.
I am hoping to splice the map from an Astra with the VX220 map, just need to remove the power steering, coolant module and A/C code that’s not needed. Not easy but worth a play.
Posted 20 September 2020 - 12:19 AM
