Lifting Points
2 replies to this topic
#1 wilksy
wilksy
  • 21 posts
Posted 18 September 2020 - 08:22 AM
I'm sure many people have asked this question so I will ask it again, I have a Quick Jack as per the picture, I would like to know where are the best points on the underside to place the 4 blocks.
I will be lifting the car up next weekend to fit my Larini exhaust system and would rather not damage the underside by going in blind.Attached File  quick jack.jpg   35.28KB   11 downloads
#2 sford
sford
  • 1,459 posts
Posted 18 September 2020 - 09:08 AM
You will have a central bezm running the width of the car, underneath the seats ish. This is the central balance point of the car. You can lift the entire car up on that beam. If you're doing the exhaust, I would suggest lifting the car from either side and then putting a wheel ramp or some blocks under either rear wheel to raise things up. You will then have space at the back of the car to get to the undertrays
Or, take off the rear undertrays, slide them out. Then jack the car from the rear turrets where the undertray attached and lift the rear of the car. Put something under the rear wheels to raise the car up and then you will see the exhaust.
#3 Arno
Arno
  • 1,238 posts
Posted 19 September 2020 - 10:26 AM
Enjoy!
https://www.speedste...g Equipment.pdf
