Hi, I posted this on the FB group a couple of weeks ago but that's not much help for getting helpful advice and now the post has disappeard. So I'm back to good old .org for help!
I have a s/c eaton on dutch, pretty standard setup.
I took the clams off to do various work, the car would start and run fine until I put the rear clam back on and now it will not start.
Symptons and checks done already are:
- Fuel pump doesn't prime, no power to relay.
- Engine cranks fine
- No spark
- 999deg C displayed on water temp
- no power to RaceTCS (pretty sure that the 12v is taken from the 'coil' feed)
- Power to OBD but no signal from ECU so I cannot connect to OBD tuner.
- No lights from the immobilser led by shifter.
- Checked earths and have continuity.
- Checked fuel pump cut out and this is OK. However, when ignition is on I do not get 12V through it (?)
- Engine light on as usual on dash when ignition is turned on (does this confirm ECU is recognised?)
- All fuses and relays seem to be fine.
Pretty sure that is everything so far. I was thinking initially that I damaged something when putting the clam back on (I started it fine a few hours before), but maybe it's just a coincidence now?!
It seems like a lot of things are not getting power but not sure why.
I'm starting to think that it might be the ECU or immobilser but wouldn't the light be flashing if there was an immobiliser issue
The LOD connectors have been replaced so don't think it's this.
Could it be a broken wire in the loom?
Any suggestions much appreciated.
Cheers
Mark
