Mot Emissions Fail
27 replies to this topic
#1 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 12 October 2020 - 09:37 AM
Failed mot on emissions this morning wondering where I start working it out.
Car been sat in the garage for 2 years so maybe should have given it a thrash before the mot.
It's supercharged. Have full tullet 2.5inch exhaust.
Pic of the test readout attached.Posted Image
Sent from my Pixel 2 XL using Tapatalk
#2 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 12 October 2020 - 10:22 AM
Looks like there is no catalyst fitted ??
#3 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 12 October 2020 - 10:36 AM
Its got the normal tullet cat for the 2.5inch
#4 smiley
Posted 12 October 2020 - 10:55 AM
Can you inspect it? (would not be the first tullett cat to fail on an SC)
#5 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 12 October 2020 - 10:58 AM
OK what is the easiest way to do that?
I take it from the replies the numbers are well out and an italian tune up wont cut it.  :lol:
#6 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 12 October 2020 - 11:45 AM
Your CO levels are very high. Are your lambda sensors OK?
#7 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 12 October 2020 - 11:47 AM
How do I check?
It idles and runs ok, no eml.
#8 Arno
Arno
  • 1,238 posts
Posted 12 October 2020 - 11:54 AM
Looking at the calculated lambda value from the MOT gas analyzer at around 0.8 lambda  it's idling and fast-idle at around 12:1 AFR.
Aka. Running pig-rich. Cat has no hope in hell to clean that up :wacko:
Possibly dying/slow primary lambda throwing off the feedback and keeping it from getting to stochiometric 14.7:1 for the cat to work.
Rad fan is not running constantly? Which could indicate the ECU is in failsafe mode.
#9 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 12 October 2020 - 12:25 PM
Fan not on no.
How can I test the primary lambda?
Can problems on the intake also cause this?
#10 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 12 October 2020 - 02:02 PM
Drop the three 13mm bolts out before it goes into the u bend. visual inspection of the catalyst.
#11 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 12 October 2020 - 04:24 PM
Can you do a temporary swap with someone local?
#12 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 13 October 2020 - 05:33 PM
Have not had time to look at the cat or anything yet but I plugged in my reader "obdlink mx" there were no fault codes. It is possible to get any useful info out of the obd port? These are the info it shows with engine at idle....
#13 Dan r
Dan r
  • 666 posts
Posted 14 October 2020 - 07:02 AM
I'm in the middle of the same problem with mine, same spec. just fitted new cat, new lambda still high CO, my next check is for an exhaust leak upstream of the lambda. Just waiting to borrow an exhaust leak test kit as its not very easy to do by eye!
Sent from my G8441 using Tapatalk
#14 ICD
ICD
  • 102 posts
Posted 14 October 2020 - 07:44 AM
My MOT guy leaves the car running for a good 20 - 30minutes before doing the emissions whilst he does all the other checks.
get the temprature  up and ensure the fans are running so you know the temp is high
Never failed..close, but never failed
#15 speedster norway
speedster norway
  • 162 posts
Posted 14 October 2020 - 09:22 AM
Test lambda.
1: In live data meny on your obd scanner watch your number 1 lambda sensor,and it must switch once a second between 0,1 and 0,8 volt
2: If it does now watch the second (2) lambda sensor .With hot engine and RPM at 3000 for about 3 min,and the sensor should be fixed at 0,6Volt approx.If it move like lambda 1,this confirms a faulty cat.
3:If the second sensor (lambda) reads either 0,1 volt steady or 0,8 volt steady the fault is elsewhere.
The engine have to be in closed loop and hot
#16 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 14 October 2020 - 04:45 PM
Stick a bung in the tailpipe(s) and see if it stops the engine.
#17 Dan r
Dan r
  • 666 posts
Posted 14 October 2020 - 04:54 PM
Going to use one of these
https://www.amazon.c...b_qzkGFbYMWGYFH
#18 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 15 October 2020 - 05:28 PM
Test lambda.
At idle>
Primary lambda cycling between ~0.025v and ~0.6v
Secondary lambda cycling between ~0.06v and 0.9v
Fuel trim cycling 0% and -6%
3000 RPM>
Primary lambda steady ~0.05v
Secondary lambda steady ~0.9v
Fuel trim steady +10%
#19 Dan r
Dan r
  • 666 posts
Posted 16 October 2020 - 08:39 AM
Just did a leak test and the flange between manifold and downpipe which is apparently not meant to need a gasket is leaking a lot, its done up well so will need a gasket. Must have warped a bit somehow as never had issues before.
Once a gasket is fitted I'll report back with CO results.
If you haven't got access to a smoke test you could gently pressurise the exhaust and squirt bubble mixture over the joint.
Does anyone know a part number for a gasket that fits the tullet 2.5 inch system?
Don't want to use any paste or silicone up stream of lambda.
Thanks
Dan
#20 oakmere
oakmere
  • 2,143 posts
Posted 16 October 2020 - 09:08 AM
Use high temp sensor safe RTV if you can’t get a gasket that fits.
