Precat Removal
precat exhaust pipo
40 replies to this topic
#1 martinf
martinf
  • 118 posts
Posted 24 November 2020 - 03:35 PM
Hi all,
I'm planning to do the 'Pipo' exhaust mod on my otherwise standard 2.2 NA. I'm also wondering whether I should also cut out the precat.
Could someone give me their thoughts please regarding the precat removal, both postive and negative.
I'm particularly interested to know:
  1. Will it make passing the MOT tricky?
  2. Will it make the exhaust noise any louder (especially with the Pipo mod) ?
  3. Will it improve the power/torque ?
Thanks.
#2 smiley
Posted 24 November 2020 - 03:44 PM
1. No none whatsoever. This has been done by the hundreds.
2. The main purpose is to relieve the maifold a little. The precat removal should not make any difference in sound. Only the pipomod does that.
3. None whatsoever. It's a bit like that playingcard you put on your bikewheel when you were 8, but the grownup version.
#3 paul_mck
paul_mck
  • 284 posts
Posted 24 November 2020 - 03:46 PM
is there not a measurable benefit to removing it? else whats the point?
#4 smiley
Posted 24 November 2020 - 03:52 PM
broem broem :tt:
#5 martinf
martinf
  • 118 posts
Posted 24 November 2020 - 04:44 PM
That's spooky, I did the bikewheel mod too - last week :happy:
As paul_mck said - surely there must be some advantage, otherwise why do it?
#6 paul_mck
paul_mck
  • 284 posts
Posted 24 November 2020 - 04:52 PM
maybe its more a supporting mod for 2.4 inlet and cams etc. Thats why I did mine, in conjunction with some other things. Dont think its worth the effort unless its coming off anyway.
#7 Lee37vernon
Lee37vernon
  • 106 posts
Posted 24 November 2020 - 11:49 PM
My cast manifold was changed last week due to a crack, in process I discovered my cat has had its innards totally removed. Doesn't seem too noisy and runs fine.. Went through MOT last time like it
#8 ayresyy
ayresyy
  • 488 posts
Posted 25 November 2020 - 07:59 AM
  I have only recently carried out a pre-cat removal on an N/A. After driving before and after you do notice a (very slight) improvement in power. It's maybe only 2-3 BHP, but its a free mod and could well prolong the life of the OE manifold if yours is still crack free.
#9 martinf
martinf
  • 118 posts
Posted 25 November 2020 - 08:18 AM
Thanks guys, Nobody has said anything negative about removing it, and it seems it might help, so I'm going to remove it at the same time as doing the Pipo back box mod.. Thanks for taking the time to give me your views.
#10 sford
sford
  • 1,435 posts
Posted 25 November 2020 - 10:31 AM
The main benefit will be that it removes the heat build up point right after the manifold and hopefully prevent it cracking. I did mine when I changed the manifold due to the crack. It made no difference to the car at the time other than the slight weight saving. About 5 years later when I went SC I noticed the manifold had cracked again although I imagine that the one I had replaced it with had probably spent most of it's life behind a precat too.
If you are taking the car apart and access is easy, then do it. I wouldn't do the one mod on it's own, more combine it with a few other jobs.
#11 martinf
martinf
  • 118 posts
Posted 25 November 2020 - 05:08 PM
Thanks, I'm just about to start the 'Pipo' mod, so it's easy to do the precat removal as well. thanks for your comments. Martin.
#12 The Batman
Posted 26 November 2020 - 02:37 AM
quickest pre cat i did was 23 seconds
feel free to try and beat me!
#13 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 November 2020 - 07:51 AM
WOT s/C running super rich? 😁
#14 oakmere
oakmere
  • 2,143 posts
Posted 27 November 2020 - 09:05 AM
I felt a difference after precat removal. not huge but noticeable with improved throttle response.
#15 oakmere
oakmere
  • 2,143 posts
Posted 27 November 2020 - 09:15 AM
#16 martinf
martinf
  • 118 posts
Posted 30 November 2020 - 11:58 AM
Removed the precat yesterday, what a stubborn little jigger. Took me about 2 hours I reckon, polished the inside of the pipe for good measure.
Now working on the back box
Sent from my LG-H990 using Tapatalk
#17 ayresyy
ayresyy
  • 488 posts
Posted 02 December 2020 - 08:02 AM
  I used a cobalt drill bit to drill around the edges and a pint of water for cooling the drill bit in. Didn't want to risk cutting fluid/oil etc getting into the main cat.
Took about 30 mins to remove that way, but they can be stubborn to get out if the car is lowish millage and fairly standard as they haven't been 'softened up' much!
#18 blackoctagon
blackoctagon
  • 167 posts
Posted 03 December 2020 - 08:46 PM
I'd do it for the weight savings.
Must be at least 80g just bogging you down there.
#19 martinf
martinf
  • 118 posts
Posted 04 December 2020 - 07:57 AM
Well, th precat is all done and the Pipo exhaust mod completed too. Since the clam is off I can't drive it, but the sound from the exhaust seems exactly the same to me.
#20 smiley
Posted 04 December 2020 - 08:55 AM
I believe the pipo mod is percieved as subtle on blast, so give it a try asap.
If you still have the oem airbox, an open cone will also make it sound more alive.
