I'm in the process of building a new engine and as I could not find a good set of figures for the balancer shafts pre and post chop I took come photos.
Shaft assembly (minus block bearing, which seems well documented as being pushed in to stem oil flow post-removal)
Keeping parts post-shaft chop:
Assembly with remaining shaft stub trimmed some more and centre drilled to loose more mass:
Assembly with a few shaves here and there. Theres another few grams to be had, but i'm experimenting with the short chain water pump solution, so i'm not chasing for now.
Z22Se Balancer Shafts And Post-Chop
Started by
blackoctagon
, Nov 28 2020 05:46 PM
No replies to this topic
