Hello,
I have a VX 220 with a Z22SE that has an M62 supercharger fitted and running at what it believe is “stage 2†(245bhp approx).
Z22SE with an M62 charger and a Courtenay map. Has been running fine, but lately I’m having serious issues with the engine cutting out and stuttering on part throttle loads.
Feathering the throttle is fine, full chat is also fine, but part throttle, from about 20% to 60% pressure it keeps cutting out for half a second or so. It jolts the car quite violently like I’m a learner driver (!) and then it recovers for a few seconds before it does it again. Once today, on a test run, I played with the throttle to try and provoke the cutting out by pressing and releasing it quite quickly, and the engine completely cut out and didn’t recover. Wouldn’t start on the starter motor, not even trying to fire, so pushed the car into a safe place. Then tried again, and it started (albeit with the stuttering problem still)!
There are no OBD error codes coming up and no EML on the dash.
Anyone got any ideas where I should start looking for the culprit? EGR Cheater fault? TPS? Air intake leak maybe? (I’ve been in there recently fixing the charge cooler water pump...)
